Subaru Legacy Forums
-   Mountain West (http://legacygt.com/forums/forumdisplay.php?f=47)
-   -   Alignment (http://legacygt.com/forums/showthread.php?t=204009)
gcallahan 03-20-2013 01:01 PM
Alignment
Can anybody recommend a good shop in Salt Lake to get my LGT aligned?
LeGiT_Flat4 03-20-2013 02:14 PM
I have the lifetime alignment at firestone, but at the one here in Riverton they seem to know very little about alignment on my LGT. They couldn't provide me a printout (printer is always "broken"), they insisted I need aftermarket camber bolts up front and didn't seem to realize that there is adjustability with the stock bolts. And the guy tried to convince me that the rear camber was adjustable by pulling up some diagrams on his computer but "for some reason" he couldn't find said diagrams. I'm thinking I will need to try a different firestone. Hopefully others will have suggestions on a reliable knowledgeable shop.
S402 03-20-2013 04:02 PM
Race co out at millers. Or innovative garage. You will need aftermarket rear camper bolts to adjust camber.
LeGiT_Flat4 03-20-2013 05:29 PM
Everything I've read indicates that rear camber bolts are a no go on LGTs. I picked up the Whiteline KCA399 bushings but have not installed them yet.
Originally Posted by m sprank (Post 3687355)
Camber bolts (rear) do not work on LGT. Only on WRX/STi. Whiteline offers KCA399 which allows 1deg more rear camber andKTA124 which allows camber and toe adjustment.
S402 03-20-2013 06:27 PM
that kca399 is what I was referring to. +/-1 degree of camber in the rear. the KTA124 is a much better solution but also much more expensive.
Killy83 03-27-2013 05:35 PM
Is Innovative Garage the shop on Ft Union and about 13th East? I need some bushings replaced, and the alignment done as well.
