Subaru Legacy Forums
-   Suspension/Brakes (http://legacygt.com/forums/forumdisplay.php?f=20)
-   -   Anyone using WL Com-C front mounts? (http://legacygt.com/forums/showthread.php?t=203980)
fahr_side 03-20-2013 12:20 AM
Seems quite new...
http://www.whiteline.com.au/product_..._number=KCA409
I watching these for a while, the KCA335 for the GC/GD chassis. I waited I think two years for these to become available for my GH8, but then WL had some problems with the 335 and suspended sales for a while. In the meantime I picked up some GRB hardened top mounts. Now these are available.
With the JDM GRF springs I use I'm just a little lower than stock and can only get a maximum of -1.0* camber. I never have liked the aftermarket camber bolt solutions out there.
.:Catalyst:. 03-20-2013 07:01 AM
In for any feedback as well. I just saw these two days ago when looking up another WL part on their website. I like the additional camber and caster adjustments, and have been considering going with Koni's and new tophats to replace my tired Bilsteins and spec.B tophats.
Nrw 03-20-2013 07:04 AM
interesting
jamal 03-20-2013 06:36 PM
I've had them for a couple years now. No problems.
AZP Installs 03-20-2013 08:25 PM
We've sold several sets and 2 guys in our shop use them on their own cars. Good stuff!
-Mike Paisan
http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/14...8/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
fahr_side 03-20-2013 08:43 PM
You mean the KCA335 on an Impreza or Forester? This Legacy-fitment part is quite new.
jamal 03-20-2013 10:00 PM
Yes, KCA335 on my Legacy. They've made some changes to it- the stiffness of the rubber, how it's bonded, and higher quality bearings, so the new one for the 05+ Legacy and 08+ Impreza carry all that stuff over and should not have any problems.
The part number for these is KCA409 btw, and none of the distributors I use even have any yet.
sjxbrd 03-26-2013 01:59 PM
Just ordered a set of these from Mike. I will install them and get the car aligned around mid April.
PirateDuck 03-27-2013 12:09 PM
I also just ordered a pair from Mike. I'm installing Konis with Rallitek springs in my wagon this month. I'll post up a review once everything is settled and aligned.
TeriyakiBBS 03-27-2013 02:09 PM
I am ordering soon and will be doing a write up and track day with them with my Bilstein/Swift setup.
.:Catalyst:. 03-27-2013 03:18 PM
These will work with the inverted Bilsteins? That would surprise me. I thought these were for the KYB style front struts.
Dbl_D718 05-01-2013 06:38 PM
How do these compare to spec.B top hats, performance-wise? The spec.B bearing would be larger, yes? How must difference does that make?
I used spec.B top hats when I installed my Konis, but I'm considering switching to these to eliminate the ride height increase from the extra washer. Would I be spending money on a downgrade?
AZP Installs 05-01-2013 06:50 PM
These are a bit stiffer than the SpecB units and also give you more camber so that's a good thing if your car is lowered or you do performance/track driving.
-Mike Paisan
AZP's First Private Track Event, June 19 at NJMP Thunderbolt $315 including Classroom and Mentor!
scoobyscoodle 05-02-2013 01:12 AM
I wonder how much more comfortable these would be than my GTworx camber plates? Meh.
I really like the additional caster the GTworx plates provide and these look to add around the same amount, and a little more camber too.
AZP Installs 05-02-2013 06:52 PM
They will be significantly more comfortable since they aren't a solid piece of metal like the camber plates are. :) Let us know if we can send you a set ;)
-Mike Paisan
