Subaru Legacy Forums
-   Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) (http://legacygt.com/forums/forumdisplay.php?f=12)
-   -   Timing belt guide? (http://legacygt.com/forums/showthread.php?t=203871)
99acr 03-18-2013 04:47 PM
Timing belt guide?
I have a 05 lgt automatic.
Does it have a timing belt guide? My engine builder said it is missing and I can't find a stock example, let alone a replacement of one. I did find an aftermarket one, but I don't see where it's a factory thing.
Hemingway 03-18-2013 05:00 PM
This may or may not help (page 3):
http://www.northursalia.com/techdocs.../dohctbelt.pdf
tdelker 03-18-2013 05:24 PM
The automatic does NOT have timing belt guides. This is not obvious in the FSM.
I found out when I changed my timing belt. Here's my thread: http://www.subaruoutback.org/forums/...lt-guides.html
Tom
99acr 03-18-2013 05:50 PM
Thank you!
DaveWaters 12-08-2017 08:48 AM
Thread back from the dead... In process of doin my timing belt right now.. I just discovered that there is no guides at all on this motor.. is it ok to add a guide over the crank as I ordered a replacement anyhow.. can it do harm. I wouldn’t think so but...
Thanks
Dave
Darth SpecB 12-08-2017 01:26 PM
Thanks
Dave
If you Have an automatic transmission I would not add a timing belt guide. There really is no use for it and it can cause the belt to be worn prematurely if not properly installed.
Sent from my SM-G950U using Tapatalk
DaveWaters 12-08-2017 04:23 PM
Thank you ... I mounted it and was unable to get the 1 mm clearance on the passenger side so I took it off.
