Subaru Legacy Forums
-   Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) (http://legacygt.com/forums/forumdisplay.php?f=12)
-   -   Not making full BOOST!! (http://legacygt.com/forums/showthread.php?t=203786)
Mohen 03-17-2013 02:26 PM
Hi Guys, my first time here. Not sure where i should post this.................
Recently purchased a 2005 Legacy B4 JDM. Been having issues making boost.
Everytime i reset the ECU the car makes a little over 1 bar of boost and then i here a ping and it go's into Limp mode which will not pass 1/2 a bar of boost. While driving you feel that the care wants to make more power but its being restricted. Anyone encountered a similar issue?
Swapped the MAF sensor, MAP sensor checked the CAT for airflow restriction but nothing works except resetting the ECU. Then as soon as i make full boost. The car pings and "LIMP MODE" again and it will not pass 1/2 a bar of boost.
Any help will be greatly appreciated.
lgtvf52 03-17-2013 02:52 PM
Welcome and I am not sure this is the cause but have you checked to see if you have a vacuum leak anywhere? I could see how this could cause something like that
Sent from my SPH-L710 using Tapatalk 2
iNVAR 03-17-2013 06:35 PM
Your car is sending you a message and ignoring it and resetting the ECU is a good way of blowing something up permanently. Stop resetting the ECU. See if you have any CEL codes. Get your hands on a tactrix/vagcom cable, and pull a LearningView and log.
bnguyenbb6 03-17-2013 06:46 PM
Audible pinging sounds great :lol:
Why don't you try boost leak testing/looking for leaks first? Pinging sounds great for your motor :lol:
Mohen 03-18-2013 07:34 AM
Thanks guys,
fuel pressure is ok, there is no boost leak noted and also i have no check engine light. We did a log and noticed a knock when it made peak boost. Going to reflash the ECU and hope for the best.
lgtvf52 03-18-2013 08:41 AM
Originally Posted by Mohen (Post 4346512)
Thanks guys,
By flashing the ecu it's the same thing as resetting it and if now you are hearing a knock when you make full boost there is clearly sonething wrong vacuum wise or internally, you can destroy the motor continuing to drive the car like that.
lgtvf52 03-18-2013 09:01 AM
Also make sure your running the right gas as stupid as that sounds that could be the problem, what octane are you using?
fahr_side 03-18-2013 10:55 AM
Good point. Many of the JDM models require 100RON fuel.
Mohen 03-18-2013 11:56 AM
Thanks, i live on the Caribbean island of Dominica and the gas we get is similar to 92-93 octane.
By flashing the ECU we hope we will to be able to adjust the fuel map and have a lil bit less aggressive timing. Any other thoughts or comments are appreciated.
lgtvf52 03-18-2013 12:42 PM
Instead of reflashing you could just try to manually retard the timing. Becareful doing that though because a little to slow can (and most likely will) cause a late ignition which can cause a knock.
fahr_side 03-18-2013 08:28 PM
How are you able to 'manually retard timing' without modifying or reflashing the ROM?
