2005 lgt 5mt
Simple question to those of you with this particular vehicle. All I need to know is MPH vs RPM in 4th and 5th gear. Thanks
For 5MT 2005 LGT:
1st: 3.166 2nd: 1.882 3rd: 1.296 4th: 0.972 5th: 0.738 Final drive: 4.111 215/45/17 wheels/tires 4th gear: 4KRPM = 73.314 MPH, 3KRPM = 54.986MPH 5th gear: 4KRPM = 96.560 MPH, 3KRPM = 72.420MPH |
Thank you. I'm swapping transmissions from the 05 LGT into my 02 WRX, along with the 4.11 final drive. I'll be running a 255/40/17 for most of the year and was curious how much higher my highway rpms are going to be.
I have a spreadsheet at home to do these calculations. I'll post it up later for you to use. You can adjust all the numbers to your heart's desire. ;)
Oh man, I totally forgot to post my spreadsheet up... later tonight :)
No biggie. I actually forgot about posting this question. I did some research and found a few things, but I'd still like to see what you have.
www.crimetank.com/misc/carstuff.xls tweak the numbers as you see fit. just something i was messing with for useful calculations. the bottom section is something i was working on for treadwear being translated into differences in rolling circumference
| All times are GMT -6. The time now is 02:03 PM. |
