Subaru Legacy Forums
-   Second Generation Legacy (1994 - 1998) (http://legacygt.com/forums/forumdisplay.php?f=95)
-   -   EJ25D and EJ22 compatibility (http://legacygt.com/forums/showthread.php?t=203676)
dark_thorns 03-15-2013 09:11 PM
Is the oil pump, alternator, timing components (obviously not the belt), and all the other external drive systems from an EJ25D compatible with an EJ22?
johnegg 03-15-2013 11:03 PM
yes.
not the intake manifold though.
r3v_v3ng3 03-16-2013 02:51 AM
Af far as timing components, no on the cam gears and probably on the crank gear also.
tytek 03-16-2013 04:31 AM
I have a set of pristine rebuilt '96 25d heads with HLA. They were done by a shop that specializes in heads with a cut and grind, deck shave, seals, and wash. PM me for more info.
'96 DOHC heads have the largest intake ports and are ideal for running a high boost application.
Kennyfvholla 03-16-2013 08:46 AM
ALL the timing components are swappable if you are using 25D heads.
And tytek.. I have a set of 96 2.5 HLA heads as well. I used to think that they'd be great for boost applications as well; but the more I learn, the more I think not. Especially since they apparently won't actually fit on a EJ22.
tytek 03-16-2013 10:01 AM
They need to be used with the EJ255 or 257 and applied to pre AVCS builds. Like an RSTI, for example. There are bunch of guys running those heads on the RS site.
DOHCEJ22E1 03-16-2013 10:06 AM
Best poor man boost builds are the following:
97-99 25D heads on an EJ22 block.
96 25D heads on a 97-99+ EJ25 block.
Kennyfvholla 03-16-2013 10:56 AM
True. I was speaking along the lines of 2.2/2.5 build. Either way, I'd rather use the 97-99 EJ25D heads. They have a better quench design, you can rev them higher, and they're just as good after some porting. I'm not saying they wouldn't work, I'm just saying the non-HLA head is a better start.
Zues Marine 03-16-2013 04:01 PM
i wouldnt do this, it'll just cause more detonation than anything
Kennyfvholla 03-16-2013 04:23 PM
What? Pre or post detonation? They'd lower the compression ratio quite a bit... I see no possibility of predetonation with that compression level.
Zues Marine 03-16-2013 04:44 PM
idk what i was reading..
but +1 to this.. i vote for the high comp. build, grind cams, etc.... easy and effective
DOHCEJ22E1 03-16-2013 05:45 PM
Everything that you have mentioned is perfectly compatible with the EJ22.
There have been some instances where I've seen the same accessories on both engines.
The 96 25D heads are better suited for TQ due to the wider intake ports & the VERY small exhaust ports. The quench chambers are suited prefectly for the 2.5 bore. These heads would be perfect for a smoothly running engine. Smoothness contributes heavily to reliability & response.
I'm running a DOHC EJ22E with 9.4:1 CR.
It isn't even close to detonation but produces more power than the SOHC EJ22E in the midrange while low-end is a little lacking but not as much as before the tune-up with the 0 resistance plugs/wires & maintenance.
Kennyfvholla 03-16-2013 05:58 PM
Originally Posted by DOHCEJ22E1 (Post 4344633)
The 96 25D heads are better suited for TQ due to the wider intake ports & the VERY small exhaust ports. The quench chambers are suited prefectly for the 2.5 bore. These heads would be perfectly for a smoothly running engine. Smoothness contributes heavily to reliability & response.
Yes, the design from the factory is better suited to lower end torque on a stock motor. I'm not disagreeing. Especially since I am ALL about low end torque, to the point of obsession almost. But, there really is just not enough of a difference to warrant getting a set of HLA heads and putting them atop a lower end that already has the cloverleaf heads that are already ported and matched to the ported intake manifold. Yes, the chambers obviously fit a 2.5 bore, but they chamber has a different design. The cloverleaf design is just better, and creates less volume in the chamber when compressed. Thus, compression is increased (especially with a Cometic 0.027" head gasket) and not only low end torque in increased, but the whole power band raises.
I've pondered over which head would be best for a boosted or NA build. I used to be all for the HLA since they used a hydraulic lifter. But, you can't rev them as high as the solid lifer heads. Currently, his motor is designed to have a bit a peaky power band. But that's nothing that some cams can't fix. Since we're not talking about that much of a difference in power and not even that much of a difference in the low end, I see no point to spending money on another set of heads. The cost to benefit ratio is just not worth it to me. If his heads weren't already ported, and we weren't talking about high compression and cams and such, I would be all for the HLA's.
Just what I would do, is all.
DOHCEJ22E1 03-16-2013 06:20 PM
Your statement about the 97-99 heads is true.
I guess it would depend on your intentions for either pair of heads.
96 25D HLA heads for the smoothness/quickness of response or the 97-99 heads for a slightly longer powerband for touring/long distance traveling. The 97-99 25D heads on my 22E come to life after about 2500rpm & the power is carried all the way to redline.
mattmattyxcore 03-16-2013 07:27 PM
So is it as simple as just swapping the heads and new gaskets? I'm trying to get to know this stuff and would love to do this! Most of my driving is highway and plenty of 25's at the junkyard.
