Subaru Legacy Forums
-   Outback Photos (http://legacygt.com/forums/forumdisplay.php?f=53)
-   -   BMB's OBXT Build Thread (http://legacygt.com/forums/showthread.php?t=203319)
BarManBean 03-11-2013 01:33 PM
I don't plan on going too crazy here (edit: OK, I lied!), but figure I may as well start this thread now :) Picked up an '05 GRP OBXT with 5MT on March 8, 2013 w/ 65,xxx miles. Southern car that was purchased near Atlanta, GA and driven back to it's new home in VA.
Right now I have quite a few parts left over from my previous LGT wagon that will go on the car as well as a handful of things that I've picked up to bring the car to stage 2. Will update here as things are installed.
ELECTRONICS/TUNING
PLX SM-AFR (wideband)
VBG1
Cryotune Performance Opensource E-tune
TURBO/INDUCTION/EXHAUST
BNR 16G, PnP'ed / ceramic coated at SoCalPorting
PTP Turbo Blanket
Cobb SF Intake with box
Invidia Big Tube 1.5 Scroll Headers / Up Pipe, Swaintech Coated
IP&T Filtered Oil Line Kit
TurboXS Catted Downpipe
Prodrive Mufflers
Thermal Zero Downpipe Blanket
Nameless Performance Heatshield
Turbo Blanket
Grimmspeed TMIC
JDM TGV Deletes
Grimmspeed 3mm Phenolic Spacers
Replacement Intake Manifold Gaskets
Forge BPV
Grimmspeed Electronic Boost Control Solenoid
Samco Turbo Inlet
Samco BPV Hose
Samco Vacuum Hoses
TurkeyLord metal "T" fitting
DRIVETRAIN/ENGINE/FUEL
2007 Spec.b 6mt Transmission w/ R180 rear differential
KDT903 Rear Differential Bushing Inserts (rear/upper mount only)
Cobb Tuning Double-Adjustable Short Shifter
TiC shifter linkage bushings (2/4 installed, chose not to install all 4)
Cobb front shifter bushings
Kartboy rear shifter stay bushing
Fumoto F105 Quick Oil Drain Valve
DW65c Fuel Pump
Injector Dynamics 1000c Top Feed Conversion Kit
Stock STi Transmission Mount
Group N Transmission Crossmember Bushings
Stock STi Clutch & Flywheel
Stock 2009 STi Oil Pan
KillerB Oil Pickup Tube and Baffle
SUSPENSION/BRAKES
RCE Tarmac 1 Coilovers
3/8" Front Spacers, 3/8" Rear Spacers
Front Brembo calipers with Brembo slotted rotors and Stoptech Street pads
Rear LGT calipers with Centric Premium rotors and Hawk HPS pads
Technafit Stainless Steel Brake Lines
Whiteline KTA124 Kit
Whiteline Roll-Center/Bump Steer Kit
STI LCA Bushings
LGT Rear Upper Control Arms with Whiteline Camber Bushings
Grimmspeed Master Cylinder Brace
Hotchkis Front (25mm) and Rear (22mm) Sway Bars
Kartboy Endlinks
AVO RSB Reinforcement Brackets
Energy Suspension Front/Rear Sway Bar Bushings
Alignment: -1.6* Camber up front, -1.1* Camber in the rear, zero toe at all four corners
WHEELS/TIRES
Summer setup: Enkei Raijins (gunmetal), 18x8/+45 w/ Michelin Pilot Super Sports in 235/45r18
Winter setup: 2004 STi BBS (dipped in Anthracite), 17x7.5/+53 w/ Michelin Alpin PA2 in 225/45r17
EXTERIOR/INTERIOR
DAMD round wheel
Tint (35% Front, 20% Rear)
'07 Head Unit w/ Auxiliary Input
'07 Spec B Steering Wheel w/ Audio Controls
Extending Arm Rest
R-Rev Reverse LED lights
GrimmSpeed License Plate Relocation Kit
Redline Tuning Hood Struts
Moddiction Convex Mirrors
SST Aluminum Undertray
PENDING INSTALLATION :)
ProSport Oil Pressure Sender
http://i934.photobucket.com/albums/a...ps157417a2.jpg
http://i934.photobucket.com/albums/a...ps893a076c.jpg
http://i934.photobucket.com/albums/a...ps23ddc6b5.jpg
http://i934.photobucket.com/albums/a...ps7cabc9d7.jpg
http://i934.photobucket.com/albums/a...ps8409bade.jpg
http://i934.photobucket.com/albums/a...ps4cea9693.jpg
http://i934.photobucket.com/albums/a...ps3945db9f.jpg
http://i934.photobucket.com/albums/a...psyqmr7woc.jpg
BarManBean 03-11-2013 01:34 PM
http://i934.photobucket.com/albums/a...psef8436ed.jpg
http://i934.photobucket.com/albums/a...psfdec5faa.jpg
http://i934.photobucket.com/albums/a...ps90e99eb0.jpg
http://i934.photobucket.com/albums/a...ps70a55307.jpg
reserved.
bucko3the7man 03-11-2013 01:37 PM
subscribed for awesome 5MTness
SCHM1AN 03-11-2013 01:40 PM
Subscribed because you're going to make me go down the same path eventually
mr.hicksta 03-11-2013 01:42 PM
Sub'd because BMB yo :D
2000_LegacyOutback 03-11-2013 01:56 PM
very nice!!!
Nrw 03-11-2013 01:56 PM
You had to go and post that undercarriage pic
BarManBean 03-11-2013 01:57 PM
Yup :D
SCHM1AN 03-11-2013 01:57 PM
dat ass!
mr.hicksta 03-11-2013 02:03 PM
My LGT's undercarriage is a picture of tragedy :lol:
.:Catalyst:. 03-11-2013 02:10 PM
Congrats BMB - glad you made the switch! 5MT + GRP :cool:
argyle409 03-11-2013 05:23 PM
Congrats on OBXT! I can't to see what you've got in store for her!
slim101 03-11-2013 05:26 PM
nice pick up mike looks good cant wait to hopefully see this thing in person!
ttnio 03-11-2013 05:50 PM
I will look for it at the classified forum...
