Subaru Legacy Forums
-   Fifth Generation Legacy (2010 - ) (http://legacygt.com/forums/forumdisplay.php?f=92)
-   -   Brake upgrades or BBK (http://legacygt.com/forums/showthread.php?t=202898)
sschmelcke 03-05-2013 09:09 AM
Can we make a sticky as to what STI brakes are compatible with the 5th gen? Ive been looking for more info on this but can only find 4th gen stuff.
whitetiger 03-05-2013 09:18 AM
If someone were to write a comprehensive thread on fitment, id be happy to sticky it.
sschmelcke 03-05-2013 09:20 AM
Lol. If I knew any information I'd make one for you.
LosAngelesLGT 03-05-2013 09:45 AM
Take the plunge. Its not as bad as you think. Find a buddy with a caliper and mock it up. See what it looks like. Brackets are easy to fabricate. Hell, my Durango has custom cut and powdercoated spindles for a bracketed wilwood kit. Not nearly as expensive as it sounds.
SpidermanMTL 03-05-2013 09:48 AM
There's a lot of info in the Parts from other years/models that fit sticky thread....
http://legacygt.com/forums/showthrea...en-143255.html
sschmelcke 03-05-2013 10:36 AM
aint nobody got time for that
redstriker 03-05-2013 11:06 AM
I have some input as I just bought some new brakes for my car.
Front Rotors/Brake Pads
05-09 LGT will fit for both.
As for the rear rotors and brake pads, we have to buy what is available for our current gen. I haven't found anything so far that is compatible with our rear brake setup.
sschmelcke 03-05-2013 11:08 AM
Thanks red!!
redstriker 03-05-2013 11:09 AM
No problem, I spent days doing research on this. I must share this info for the greater good!
CL21376 03-05-2013 11:17 AM
I thought the 5th gen had larger front rotors than the 4th gen?
I had hawk hps pads on my 5th gen, front & rear. I didn't change rotors as they only had 10,000 miles on them when I switched pads.
Rutchard 03-05-2013 11:22 AM
05 and up front Brembo calipers fit, 08+ for rear Brembos.
04 STi rotors up front to fit the 5x100 bolt pattern. Then I think people were having 08+ STi rear rotors redrilled for 5x100
fredrik94087 03-05-2013 12:23 PM
And, here is my summary...
Here's my gathering from reading this "sticky"
Parts from other models/years that fit our 5th gen
2004--->up Brembo FRONT caliper
2004--->STi Front Rotor
2008--->up Brembo REAR caliper
2008--->up rotors will need a kit. KNSbrakes sells them as of this post, but not sure if Fred beans sells them.
# These Brackets allow you to mount Gold Rear Brembo Caliper (04-07 STi) or Black Rear Brembo Caliper (07 Limited STi) or Red Rear 2 pot Caliper (06-07 WRX) on to your 2010 - Up - Subaru Legacy
Any 2004 STI wheel
2008-2012 WRX rotors and brake pads are direct fit according to RCE.
Checked 2011 Legacy 2.5i rotors and brake pads are same product number as the 2008 WRX so it looks like the 2008 and up WRX or 2011 Legacy rotors and pads
redstriker 03-05-2013 12:46 PM
When I was comparing part numbers, the 4th gen had the same part number as the 5th gen for the front rotors.
As for the front brake pads, it looks like the Hawk HPS for the 4th gen fit the 5th gen.
DeltaSniper 03-05-2013 01:00 PM
So 2008+ STI Front calipers will work, but not the rotors?
So for the BBK upgrade, it would be wise to buy a set of 2008 STI calipers and just get 2004 front rotors and dual drilled 2008 rear rotors from KNS?
fredrik94087 03-05-2013 02:44 PM
Check with KNS brakes. And, from the original thread, my understanding is that the STI Brakes are a direct fit for the front...rotors included.
You need a kit to make the rears fit.
However, you can go the 2008+ WRX route and they will all fit (replacement/upgrade parts for worn out parts)
Going the TI/Brembo route would cost me around $2000 in parts alone. Before I do that, when I'm getting replacement parts, I will get steel braided lines, slotted rotors, and better pads. (I know the slotted rotors will make the pads wear faster...I just want the "bite")
Cheers!
