Subaru Legacy Forums
-   Second Generation Legacy (1994 - 1998) (http://legacygt.com/forums/forumdisplay.php?f=95)
-   -   1998 Legacy GT front bumper cover (http://legacygt.com/forums/showthread.php?t=202630)
penrod 02-28-2013 10:20 PM
Sorry if I offend by not looking thru lots of your site's specifics but my son has just bought a 1998 Legacy GT. It needs a new front bumper cover.
1) Are 1998 Legacy and Legacy GT front bumpers the same?
2) What other years of Legacy's have the same bumper as a 1998 Legacy GT?
I would appreciate your help as I seem to get conflicting information from the internet otherwise.
Thanks
spooln30 02-28-2013 10:38 PM
No the Legacy and LGT front bumpers are different. I think all 96-99 LGT and LGT limited bumpers are the same. Just the limited ones are fully painted and the LGT lip is black.
r3v_v3ng3 03-01-2013 02:02 AM
1)Yes the 98-99 legacy bumpers are the same gt or not with the exception of the outbacks
2)The 97 GT have the same bumper
Sludgeroo 03-01-2013 05:04 AM
Any second gen Legacy GT bumper will fit over your bumper cover. So will an outback, you just wont have mounting points for the fogs on the bumper beam.
If you get a Legacy L or Ts bumper, it will fit no problem, but the grille is shorter and will need the accommodating grille, as the outback/gt grille height wont allow it.
But you can put an L grille on a GT.
If you can find a Legacy Brighton, it will have the same bumper.
Like I said, all look similar and fit just need to switch some simple stuff around to fit.
Good luck, and let us know what you find.
r3v_v3ng3 03-01-2013 09:21 AM
^The OP is asking for the same bumper as the 98 GT
Zues Marine 03-01-2013 03:16 PM
and now he's got options^
johnegg 03-01-2013 04:59 PM
all lego, GT, LSi, outback, bumpers 95 - 99 will swap. with limitations.
the outback and the GT grilles are taller, they hang down lower, so the bumpers are shaped different to accommodate. but the bumper / grille combination will swap onto any of the cars listed above.
fyi: rumor has it that the outback grille and the GT grille will swap with no other changes.
Bandit240 03-01-2013 10:06 PM
I found that with my 1995 L I had to also change the metal and plastic core of the bumper to change to the GT bumper skin. As has been said, the grille is taller and requires the cut out that the inner bumper has in order to work. The inner bumper was easy to remove, just 4 big bolts on the frame rail once the skin is removed. Or just undo the skin from the fenders and unbolt the bumper and it all comes out as a unit. Didn't find that out until I already removed the skin.
Kennyfvholla 03-02-2013 12:41 AM
Okay....
ONLY 97 to 99 GT bumper covers are the same as the one on the car now.
You can replace it with any 96 to 99 Outback bumper cover as they use the same support bar and grille type.
If you're looking for the same one as on the car, your best bet is to just buy a brand new one from the dealer. Finding one used and paying for the shipping isn't worth the cost.
