PLX OBDII unit for Android
I am selling my PLX Kiwi Bluetooth device. Below is an overview of what this product is. It's for use with android devices. Looking to get $85 for it.
"Kiwi Bluetooth is a plug and play automotive tool that connects through the onboard diagnostic port (OBDII / CAN) in cars made in 1996 to current. Kiwi Bluetooth installs in seconds to interface with your car's computer and sync with your Android mobile device through a wireless Bluetooth connection. The Kiwi Bluetooth allows you to efficiently monitor your car's MPG, analyze the log, diagnose trouble codes and monitor real-time engine performance. Vehicles that are 1996 and later are all equipped with an OBD2 port making it compatible with 1996 and later vehicles. It incorporates an elm327 compatible interface and it works with ISO9141, VPW, PWM, and CAN protocols. " Features: Depending on the application, the following features may be available: Check Engine Diagnostics Real-time gauges Fuel Efficiency and MPG Engine Sensors Customizable Dashboard Real-time Dyno Data Logging GPS Track Mapping Skid Pad Video recording and data overlay http://www.plxdevices.com/product_in...=GSSTBLUETOOTH I'm selling because I bought an IPhone and there's a different unit associated with the IPhone that interfaces using WIFI instead of Bluetooth. Located in Colorado Springs. |
I might be interested but would like to test it out first in that case. Are you ever up in the DMA though because for $11 more I could save gas and time an get it shipped brand spanking new to my door.
Nm, found something else I'll give a try, glws :)
| All times are GMT -6. The time now is 10:54 PM. |
