Cannot log WOT pulls
4 Attachment(s)
I have done tons of research on this problem with no fix yet. My issue is this; I can flash, use learning view and log normal driving without any issues. As soon as I try a WOT pull, it cuts out anywhere from 3-4.5k. When it cuts out, romraider says "connecting". So far this is what I have done to try and fix:
Load test battery (597 out of 600cca and 12.97v) its good Check and clean engine grounds (two head to frame and the top of tranny) Installed 3 ferrite magnets on the OBD harness before plug Installed 1 ferrite on the vagcom cable after the OBD plug Disconnected my phone charger Turned the radio and A/C off I have tried logging with vagcom and a Tactrix 2.0. I have also tried stand alone SD card logging with the Tactrix and it doesn't turn off but the data is sporatic and repeating. I have included a log from each style and posted them labeled accrodingly. Any help would be greatly appreciated because I have to start this tune with Cryo. |
OP knows this already, but for everyone else:
As I mentioned in the other thread, a whole bunch of people seem to have this issue too... Can't figure it out. And like I mentioned, I used to have this problem intermittently with an APv2 (silver dongle, sold it already) and my vagcom cable. The problem then completely disappeared with the vagcom after a while. This guy just posted a thread about his AP having this problem: http://legacygt.com/forums/showthrea...ot-202461.html |
I read you're thread. You replaced the entire ECU? Was it reprogrammed for your key?
I found an ECU on car-part.com for $125 + shipping. I replaced my old ECU with it and reprogrammed my keys (I have access to Subaru's SSM tool if I ask nicely) with the codes on the small metal tags that came with my keys when I got the car. Flashed it with my map, started it up, and completed a log.
Just encountered this problem today for the first time in my car using a Tactrix 1.3. Pretty upsetting and it better not happen again!!!
I'm assuming that the connectors on the OBD2 port itself are wearing down or losing connection. I had this problem sometimes and problems connecting other times. Try picking up a OBD2 extension and plugging the Tactrix to the extension(leave the extension plugged in). That way, when the connectors wear down, you just replace the $20 extension cable.
Works for me... |
Talked to Mike at Tactrix today. He had me send him all of my SDcard logging data. It looks like its an ECU issue as Strizzy encountered. He said that the data loss appears to be caused by the ECU lowering the priority of the OBD port during those times. Therefore, dropping the connection.
That would be weird though because my own problem went away on its own... Unless maybe mine was just caused by a bad connection, hrm.
I may just check the ecu connections and try again. Could be something a wee bit loose from the factory, who knows.
This used to happen to me a lot. This was the main reason why I switched over to the AP.
I also had the same problem with my AP which is why I sold it.
I slightly bent the pins on my tactrix cable to get a better bite on the port. Solved my problem - but they eventually (after a few months) loosen up again - rinse and repeat.
The OP2.0 is only a week old. I wish the pins were the problem :(
Spoke with Mike at Tactrix again yesterday. He is having me add in "showsample = 1" in the .cfg file to narrow down repeat data. I have also extended the logging interval by 15 miliseconds to help the communication complete. I'll post up results tonight after I log with the changes.
| All times are GMT -6. The time now is 12:51 PM. |
