Subaru Legacy Forums
-   Suspension/Brakes (http://legacygt.com/forums/forumdisplay.php?f=20)
-   -   help needed: dust boot removal (http://legacygt.com/forums/showthread.php?t=201975)
washingtonOBXT 02-19-2013 10:49 PM
1 Attachment(s)
im changing out my struts and springs for king springs with 04 kybs in the rear, i got the spring and top hat off, but how do i get the dust boot off? a picture is attatched to illustrate what mine looks like. also, i did not see a rubber bushing that many struts have, is this because the bump stop is on the frame of the car?
washingtonOBXT 02-20-2013 08:55 AM
im doing this this afternoon so i need to figure it out, any help would be much apreciated
Rester5350 02-20-2013 09:35 AM
I used a thin flathead screwdriver to brake the grime loose and pulled it off. I also think that I started from the inside of the boot. Good luck.
Dbl_D718 02-20-2013 04:50 PM
It just pulls off, but it'll be stuck on there pretty good. I didn't need any tools to get them off though; just pulled/pushed until it came off...wasn't too hard.
mwiener2 02-20-2013 05:36 PM
pull harder
Underdog 02-20-2013 06:18 PM
If you really get stuck you can use channel locks to grab a third of the boot at a time and pinch it slightly to loosen the rust between the boot and the shaft.
Rester5350 02-20-2013 06:25 PM
If you play with it enough it will come!:p
Rester5350 02-24-2013 05:18 PM
How did everything work out for you?
