Subaru Legacy Forums
-   Detailing, Maintenance, and Long-term care (http://legacygt.com/forums/forumdisplay.php?f=56)
-   -   Royal purp worth it? (http://legacygt.com/forums/showthread.php?t=201901)
Gritter99 02-18-2013 09:01 PM
Worth the extra price? Best place to get it?
apexi 02-18-2013 09:37 PM
In my opinion, absolutely not. Every used oil analysis I've seen for royal purple has been mediocre at best. If you're gonna spend that much on oil, I'd highly suggest Red Line or Amsoil instead. Whether or not the high priced synthetics are worth it is a whole different discussion.
bluesubie 02-19-2013 05:46 AM
Most people base RP uoa comments on the 5W-30 or 10W-30. Try 0W-40, 5W-40, or High Performance Street.
-Dennis
quick4dr 02-19-2013 01:38 PM
my motor burned the royal 5w30 quickly, switched back to regular generic oil and no more burning, now I run Rotella T6 5w40 with no burning. cant beat 23.99 a jug. My last car 98 Grand Prix GTP loved the purple never burned a drop.
Tooslick 02-20-2013 04:13 PM
Their 10w-40/HPS would probably work fine and has a stout additive chemistry. From the used oil analyses I've seen, the regular RP 5w-30 will shear down significantly in a turbo. So I would not use that grade.
TS
Van Pelt 02-20-2013 09:50 PM
Can't go wrong with Redline.Cheaper than RP Hps and every uoa looks good.
scoobyscoodle 02-20-2013 10:23 PM
No. RP is garbage.
KCwagon 02-21-2013 07:16 AM
Royal Purple is Junk....really
Tooslick 02-21-2013 08:45 AM
I've been an Amsoil dealer and mechanical engineer for thirty years and I can tell you that Royal Purple is a reputable company. Their industrial lubricants - particularly their compressor oils and gear lubricants - are highly regarded. It's certainly possibly to get good results with their engine oils in Subaru turbos if you choose the correct oil for this application. The 10w-40/HPS I cited above should work very well, given its physical and chemical properties.
TS
paintpollz 02-21-2013 09:15 AM
TS
I have heard the same about their oils and gear lubricants. And while there most likely a good oil made by them that can be used in our applications, there are much better alternatives like Amsoil, or much cheaper ones like Rotella. There is no need to dabble with the purple haze for these Subarus.
ClimberD@HexMods 02-21-2013 09:19 AM
No :)
mustangendsley 02-21-2013 10:22 AM
Nope.
ecoflame 02-21-2013 03:51 PM
Howdy yall, in your opinion what would be a good brand to use in a N/A 2.5?
F1inspiredLGT 02-21-2013 04:15 PM
Just about all SAE certified oil is good enough for an N/A motor. The brand is your choice. Regular schedule changes and proper weight is the key.
mustangendsley 02-21-2013 04:41 PM
im a valvolin guy so i use there 5w 30 synthetic all the time
