Subaru Legacy Forums
-   Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) (http://legacygt.com/forums/forumdisplay.php?f=12)
-   -   Oil Consumption after switching to Synthetic (http://legacygt.com/forums/showthread.php?t=201335)
need bb 02-08-2013 02:22 PM
I have been using DINO 5w-30 oil for the last 70K miles. Since going with a larger turbo last year I finally decided to try synthetic and I recently switched to Rotella T6 5w-40. About 1500 miles after switching to synthetic, I noticed that the engine was about a quart down and topped it off. Now that I am at 3000 miles the oil is again down a quart. I never had any oil consumption with DINO and I was wondering if it makes sense to stay with synthetic or switch back?
Thanks
KCwagon 02-09-2013 09:38 AM
I use Rotella T 5/40 synthetic and I do not see any oil loss until about 2500 miles into a change and then I am only adding 1/8 of a quart when it is low. My engine has 146,000 miles on it.
Even though your consumtion is higher, I would not worry too much about it. You could get an oil analysis to make sure everything is happy though. I would also make sure you are reading the dipstick under the same conditions each time. Our dipstick is a bit dodgy to read.
Balrock 02-09-2013 09:57 AM
There have been threads in the past about people switching to synthetic and then the car starts eating some oil. I always used synthetic oil, until I bought this car. I generally don't see a loss of oil unless I am getting on it semi hard. Like the above post stated, 1qt every 3,000 is considered normal. However, since you switched oils you will have to monitor to establish a new norm.
azca 02-10-2013 03:18 PM
check for oil leaks, especially around TMIC
JJr 02-10-2013 03:46 PM
Used dyno for 67k, no oil use. Found this site 18 months & 10k miles ago and switched to Rotella T6 5w40, still no oil use, car is stock right now, going stage1 maybe that will change things!
Maxim_X 02-16-2013 10:54 PM
1 quart every 1k is considered acceptable by the manufacturers.
KCwagon 02-18-2013 03:31 PM
Can you please share the source of this information ?
A quart every 1,000 miles seems a little much.
Zero1 02-18-2013 03:36 PM
It is a lot (mine does this :( ) but any Subaru tech will tell you this. Kinda SoA's way of dodging the bullet. It usually is more noticeable when you have a larger turbo and are running higher boost. Damn non-forged internals and shotty rings...
bluesubie 02-19-2013 05:42 AM
Stick with Rotella. The synthetic oil is cleaning out all of the dino crap. If consumption continues after 3 oil changes, try a High Mileage synthetic like Max Life Full Synthetic or Mobil1 High Mileage. The additional seal conditioners may help. Your consumption really isn't that bad though IMO.
-Dennis
