Subaru Legacy Forums
-   Transmissions (http://legacygt.com/forums/forumdisplay.php?f=79)
-   -   what clutch should i get for my 2005 legacy gt.... (http://legacygt.com/forums/showthread.php?t=201129)
subidoony 02-05-2013 03:43 PM
my clutch is slipping in my 2005 legacygt 5mt ....what clutch kit should i buy for it??? i was thinking about a act clutch kit....
lingling1337 02-05-2013 03:51 PM
Depends on what kind of power you're planning to make, me personally I wouldn't go with an ACT kit unless I was planning on at least stg 2
iNVAR 02-05-2013 04:32 PM
you should get the clutch kit that can search the forum for you. this place is a WEALTH of information. if you can think of a question, chances are it was answered in detail numerous times.
btw, i'm in nyc too. ;)
ctlex 02-06-2013 01:37 PM
i have an act hd ss kit. do not get it!!! horrible chattering but good pedal feel. next time ill be going with the clutchmasters fx300
KartRacerBoy 02-06-2013 02:00 PM
I'm stage 2 since 15k miles. Clutch replaced at 103k miles. Stayed with stock clutch. No problems. If you don't place Speed Racer every day, the stock clutch is fine. If you tend to beat your car, get a stronger clutch but beware. Lots of horror stories on here about aftermarket clutches giving up the ghost in 15k miles.
Island Style 02-06-2013 04:57 PM
I put down around 340hp/370ftlbs on my STI...I've used the Exedy Organic Stg1 clutch...nice and easy on leg and about 30% more grip than stock...enough to hold my 18g STI's power...Equivalent ACT clutches are too hard on the left leg...
I did install an ACT Streetlite flywheel with it though...together with a Cobb lightened pulley and EL Header...the car sounded like a sport bike...fun!
Max Capacity 02-07-2013 08:35 AM
Contact Mike at www.AZPinstalls.com email him
He'll only sell you what you need. His guy's can install too.
ScubieSteve08 02-08-2013 11:28 AM
hey subidoony how many miles on that clutch? and I don't mean in anyway to thread jack but im having the same issue and instead of starting a new subject I figure any inputs here well help both of us out! I know a lot of smart and great people on the forum.
Ok so I have a 06 LGT with 63k miles on it been stage 2 since about 38k today my clutch stated to slip while getting on the highway. I know my time is coming so after feeling this today I need to get a plan started. My list of mods is K&n drop in air filter, Cobb AP, Invidia UP, Cobb DP, magnaflow catback and running the stage 2 93 octane map. Now my driving style varies from driven like miss daisy in daily bases but also like to have fun with my car I wont be on it everyday but I will clear out the exhaust pipes every once in a while, maybe do some donuts in the winter time. So im looking to deff upgrade the clutch specially since the car isn't stock and eventually I plan on doing more to it but as of now shes my Daily Driver! I know a lot of people also convert from my dual mass factory set up clutch to a single mass from a 06-07 wrx. I don't mind the pedal feel from an 06 wrx so converting it is no issue also saves me money :) but I want something that can handle stage 2 power or a bit more with nice smooth pedal feel for dd driving but I don't want a chattery noisey clutch either. Also wanted to know if I should get a lightened SMFW instead of a stock wrx one.. thanks for the imputs guys!
wurkenman 02-08-2013 01:29 PM
I have the ACT HDG6 in my car. It is NOT very street friendly. I chose that one because at the time my son was having issues with the clutches not holding in his 92 Legacy with a JDM WRX engine tranny swap. Do NOT get a Spec clutch. I wouldd suggest the HDSS ACT clutch for street use. The HDG6 is a sprung 6 puck clutch where the HDSS is a full fiber clutch disc.
ScubieSteve08 02-11-2013 11:29 AM
MaxCapacity what are you running?
Max Capacity 02-11-2013 01:25 PM
Spec 2 clutch with thier LWFW which I would not do again. You lose low rpm drivibility with a LWFW.
cheeseburger 02-12-2013 03:59 PM
Exedy stage 1 with ACT streetlite flywheel. I'm stock other than that but plan on doing catless UP and DP as well as tune. Love the clutch/flywheel setup
robitrice 02-18-2013 05:36 AM
Exedy Stage 1 with WRX SMFW, stock clutch feel, and hold my stage 3 power fine.
BlackHole 03-10-2013 08:22 PM
DXD Stage 1 + WRX flywheel was a huge improvement over the stocker and can handle most stage 2s - VF52 or similar turbos.
xt2005bonbon 03-12-2013 05:42 PM
How many miles do you have on this clutch with stage 3 power?
No chattering issues?
