Subaru Legacy Forums
-   Fifth Generation Legacy (2010 - ) (http://legacygt.com/forums/forumdisplay.php?f=92)
-   -   All lit up (http://legacygt.com/forums/showthread.php?t=201088)
RailKill 02-04-2013 08:52 PM
All lit up
1 Attachment(s)
So I'm on my way home right now and my dash lit up with a solid check engine light and traction control and blinking cruise and parking brake lights....
Attachment 141005
Sorry for the bad pics. Anyone know what this means?
islandborn 02-04-2013 09:11 PM
Check codes. Mine did that a couple of nights ago. Basically overboost or whatnot - p0108 was my code. I took out my AP, cleared it, and haven't had it comeback since. Did a bunch of WOT on all gears too just to see. I'm boosting at @20psi and I think im in the upper area of touchiness for the MAF so it was a very cold night and I might have put just too much air flow that the sensor freaked.
Blizzard 02-04-2013 09:11 PM
They all go off when a CEL is triggered. Learned that during my CNT downpipe fiasco because the car threw a code for the o2 sensor.
RailKill 02-04-2013 09:36 PM
You would think that just the check engine light would come on, not everything. I couldn't even use my cruise control.
Is there a way to pull codes without having to go to the dealer?
Ellesedil 02-04-2013 09:50 PM
Have an Autozone near you? I've had them read a CEL before on a previous car.
Brainchild Customs 02-04-2013 10:12 PM
Ive had the same experience as islandborn. Usually on a 3rd or 4th gear pull on a cold evening.
RailKill 02-04-2013 10:16 PM
This happened in fourth gear as I was merging onto the highway. It was about 25 degrees out, not much different than its been the past couple of weeks. And I wouldn't consider it a 4th gear "pull" on a 2.5i:rolleyes::)
nstg8r 02-04-2013 10:24 PM
Pep Boys does it as well
RailKill 02-04-2013 10:26 PM
They just opened an Advance Auto about 25 min from me. I'm going to stop in tomorrow on my way to work
nstg8r 02-05-2013 06:54 AM
If I remember correctly, you work nearby me, correct? I have an old OBDii code reader. I've already used it to pull a code and reset the CEL on my car, so I know it'll work on yours.
SCASEYS 02-05-2013 06:57 AM
http://legacygt.com/forums/showthrea....html?t=200307
this thread applies to all makes and models
http://www.bedug.com/pics/smiley/icon_fap.gif
SpidermanMTL 02-05-2013 07:06 AM
Try a reset and see if it comes back on... Mine lit up and after a reset it went away...... and never came back.
gened1 02-05-2013 07:55 AM
Mine did this
Gt mine has done this Several times now. Once for a code PO420.A Low Catalytic efficeniency test was done and a converter and sensor was found operating as designed. They reset it.
Next this past Jan a PO171 lean monitor A/F sensor output was incorrect They installed a 22641AA54A Front A/F Sensor and cleared codes. No problems yet but All this after my engine was replaced due to a dealer Tech performed faulty oil change makes me not trust this car. 21000 miles on the car now.
So far all under warranty.
You would think that all the lights would not come on just the engine check light but that's the way Subaru works
Rutchard 02-05-2013 07:56 AM
Better to scan first and find out what the code is before resetting. It's probably a stupid code, but better safe than sorry.
RailKill 02-05-2013 07:59 AM
I appreciate the offer but I work evenings and it seems everything at work breaks when its cold out so I probably couldn't get over by you. I'm going to stop at AAP on my ride in. Thanks buddy :)
