Subaru Legacy Forums
-   Interior/Audio (http://legacygt.com/forums/forumdisplay.php?f=22)
-   -   Prosport Evo Oil Pressure and Temp Problems (http://legacygt.com/forums/showthread.php?t=200949)
downtoearth 02-02-2013 08:06 PM
hello
i've had my prosport EVO oil temp and pressure gauges hooked up for about 10 months now, no problems.
Recently, my oil pressure gauge has been tanking to 0 at idle and when a high electrical load (turning fan on max) is applied.
hoping to solve the problem i rewired everything from my previous set up to connecting it to the IG2 fuse and grounding the gauges directly to the frame. that did not solve the problem, so i then re did the wires from the senders of both gauges, cleaned it up and re organized all the wires down below...
this also did not solve the problem
i find it hard to believe that it's a bad sender because the problem is only seen with high electric loads. The temp gauge is also sometimes affected (about a 5* rise in oil temp with blower on high)
any suggestions? things to check
i almost think this is a sign my alternator is in the first stages of taking a permanent vacation.
downtoearth 02-05-2013 03:15 PM
if anyone is curious, i believe it was the sender, 1.2ohms with power to oil pressure gauge
ordered a new one...
sigmafour 02-10-2013 11:00 PM
I was more thinking it was just because it was a prosport.
