Subaru Legacy Forums
-   Detailing, Maintenance, and Long-term care (http://legacygt.com/forums/forumdisplay.php?f=56)
-   -   All my blinkers won't work (http://legacygt.com/forums/showthread.php?t=200932)
rox 02-02-2013 04:58 PM
Not sure where to post this so I posted it in another section as well.
All of my blinkers, front, rear, and mirror blinkers all don't work all of a sudden. All other lights and electronics work and the fuse tested to be fine. I was going to replace it just to be sure. Does anyone have any idea what else it could be?
Really hope I don't have to get into the steering column and check the dang connector.
Any advice/help is greatly appreciated!
Thanks!
ShrinerMonkey 02-04-2013 06:53 PM
Might be a bad relay. In my old Volkswagen the relay for the flashers was located in the hazard switch.
halwith 02-06-2013 04:49 PM
@rox- you should take a moment to fill out your profile with year make model so peoples with knowledge can help. ShrinerMonkey is a sterling example of this for you.
snowdrift86 03-24-2013 12:19 AM
I have the same problem and no one here was helpful...I asked months ago
kirbwrx 04-04-2013 05:42 PM
had a friend with the same problem, turned out to be the relay under the steering column.
KLTMO 04-23-2014 01:32 PM
My blinkers and emergency flasher do not work, 2001 Legacy Wagon, I have replaced the multi switch and flasher. Dealer said it "might" be a module. Any ideas???
