Subaru Legacy Forums
-   Transmissions (http://legacygt.com/forums/forumdisplay.php?f=79)
-   -   A difficult to explain noise.. Know it's something not sure what.. (http://legacygt.com/forums/showthread.php?t=200881)
iv_05gt 02-01-2013 03:48 PM
Ok to start.
I'll be totally honest, I generally drive my LGT like I stole it. I've launched it a few times but generally just drive like a dickhead.
It's an '05 stage 2+ (bnr 16g @ 19.5PSI, tmic, AEM intake, ebcs, comp clutch & lw flywheel) w/ 137k
That being said.. The noise in question sounds like a combination of:
whirling
whining (not like the normal gear whine)
fluttery ish
It happens in any gear, or at say 70mph on the highway no gear.. clutch disengaged or engaged.
I know it's not going to be a cheap fix, and i'll probably do an overhaul on it.
What are your thoughts/idea's?
TeriyakiBBS 02-01-2013 11:25 PM
Your best bet is to get it on a lift and listen for the noise when the wheels rotate in gear. I have the same issue in my car. It is the bearings in your Center Dif/Transfer Case back housing. There is 4 bearings total in the back housing. all you have to do is drop the exhaust, driveshaft and pop the rear housing off and you should be able to do it all yourself. There are a couple DIYs on the interwebs about it. Or you can wait for when I do my write-up after I am done swapping my bearings out :) in total the bearings are around 220ish from the dealership
iv_05gt 02-02-2013 01:54 PM
Any permanent issues that can come up in delaying repairs?
charlie_sheen 02-02-2013 02:06 PM
throw out bearing
TeriyakiBBS 02-02-2013 05:11 PM
Bad bearing can lead to mis-alignment and case damage to the center dif and transmission
iv_05gt 02-02-2013 11:14 PM
Originally Posted by charlie_sheen (Post 4275302)
throw out bearing
TOB is new. w/in the past 25k.
iv_05gt 02-13-2013 12:55 PM
Do you know the part numbers for this or is it something the dealer can pull up.
archer1.8 02-13-2013 01:10 PM
wheel bearing?
iv_05gt 02-14-2013 05:08 AM
Originally Posted by archer1.8 (Post 4292864)
wheel bearing?
All 4 were done with in the last 5k.
Max Capacity 02-14-2013 01:09 PM
Take your VIN to the dealer, they will get you the right stuff.
mwiener2 02-14-2013 02:07 PM
Go to a shop
Swine 03-06-2013 09:28 PM
this noise?
http://s266.beta.photobucket.com/use...4ae9d.mp4.html
center diff bearings.
If you turn full lock at slow speeds and you get clunking your center diff is probably shot as well.
malimx6 10-12-2014 05:48 PM
hey guys...i didn't want to open a new thread because i am unsure what is causing my noise but sounds like it's similar to this thread so I decided to ask here.
I noticed a noise in the last few months, maybe a year, but i can't figure out where it's coming from - front or back. Noise is noticeable after about 60-70km/h. It sounds like whining or more like buzzing, like an electric motor. I hear it all the time, so clutch in or out. Also it gets louder with speed not with rpm. So if i drop it to lower gear noise is same, but if i accelerate noise increases.
It really sounds like an electric motor.
I just replaced my clutch, but noise is still there. Both bearings in clutch were replaced - pivot and release bearings.
Does this sound like central diff bearing?
if it does, where is this bearing? is it in transmission?
Thanks guys!!
malimx6 10-12-2014 06:26 PM
I just listen to the audio Swine posted, that's not the noise I have. Mine sounds like an electric motor, more of a buzzing noise.
Max Capacity 10-13-2014 11:24 AM
Is the noise there at idle in neutral ?
