Subaru Legacy Forums
-   Fifth Generation Legacy (2010 - ) (http://legacygt.com/forums/forumdisplay.php?f=92)
-   -   Cobb AccessPORT (http://legacygt.com/forums/showthread.php?t=200536)
ABomb90 01-27-2013 08:54 PM
Cobb AccessPORT
Anyone have any problems mechanically after flashing with AP? Just Curious and want to be prepared. I've seen my friends Audi A4 with the APR stage 2 tune blow out his diverter valve and fuel pump.
redstriker 01-27-2013 09:56 PM
No, just flash Stage 0 or Stage 1 and you will be fine.
minuccims 01-28-2013 04:02 AM
This and NEVER run 91 octane on a 93 map.
acumenhokie 01-28-2013 06:21 AM
Installed it almost 2 years ago and haven't looked back.
pfoyle 01-28-2013 06:36 AM
No problems here, do it! The only regret you'll have is not doing it sooner... and if you can find a good tuner near you (or just get Brentuning to e-tune for you!), the gains will blow your mind! Pro-tune : Cobb OTS Stg 1 Map :: Cobb OTS Stg 1 Map : Stock. (your SAT practice for the day)
Rutchard 01-28-2013 06:43 AM
I kinda thought the DV was a weak link on the Audi to begin with. Just about every VW/Audi owner I know has had DV issues.
ABomb90 01-28-2013 06:48 AM
Thanks Guys. I cant find 91 octane in Florida only 93 so I think ill be good with detonation. ProTune will be from AWD Motorsport in Coral Springs once I do the Fuel Inj and Turbo Upgrade W/ front mount, but thats a couple years from now :( Appreciate the feedback for my first purchase for my LGT
ABomb90 01-28-2013 06:50 AM
Its cause their made of plastic. APR makes an aluminum one. A BOV will throw a boost leak code also.
Blizzard 01-28-2013 05:42 PM
No issues. Been tuned for 27k.
satkye 02-02-2013 09:39 PM
My car exploded when I did it. I am reporting from the afterlife.
tuck16 02-04-2013 03:19 PM
I think i am jumping in on an AP :)
keeping it stock, im in the NW and we have 92 oct gas so ill stick with the 91+ stage 1 to start. What could i expect in gains if any from a pro tune stage 1? I was hoping for marginal gains over the OTS map and could a pro map shift the torque and/or hp earlier in the rpm's?
Thanks
tuck16 02-04-2013 03:20 PM
Thanks
pfoyle 02-04-2013 04:32 PM
1 Attachment(s)
Thanks
I got HUGE gains over stock, as well as the OTS map from my pro-tune... See attached pic (Invidia CBE, but that's not likely to have provided much power... all done on 93 octane gas, so YMMV). Red lines are stock HP/Tq, pink was Cobb OTS 93 octane map, Green is pro-tune. :eek:
Nadal4Hand 02-04-2013 05:32 PM
Thanks
http://legacygt.com/forums/showthrea....html?t=180397
:p
eckseleven 02-04-2013 06:09 PM
My results:
http://legacygt.com/forums/showthrea...ts-186860.html
The 3rd graph is the helpful one. Much more torque earlier on and more horsepower throughout.
