Subaru Legacy Forums
-   Interior/Audio (http://legacygt.com/forums/forumdisplay.php?f=22)
-   -   05 LGT Dual zone conversion? (http://legacygt.com/forums/showthread.php?t=200469)
driving 01-26-2013 08:36 PM
I have a dual zone 05 LGT but want to install either Aftermarket headunit OR Factory 07-09 Unit. Ive found many 07-09 headunits online for cheap but am unsure since none have the "dual zone". Will my A/C and heating plug and play/work? I dont care about different temps just want A/C and heat to work and better music.
Thanks for any help.
famaya26 01-26-2013 08:41 PM
If you want to go Aftermarket then you will need to browse this thread
http://legacygt.com/forums/showthrea...ad-113589.html
driving 01-29-2013 05:00 PM
Just wanna know if non dual zone controls can be used in a dual zone car. I dont care if i lose dual zones just want ac and heat to work if i switch them.
AkumaMax 01-29-2013 06:29 PM
if you have the digital controls only the digital controls will work. Manual(knob) controls only work on Manual(knob) Controls. If you are looking to upgrade to an 08 headunit to have AUX in you are looking for a P-204UH headunit. the only other way to get a different headunit is to buy the JDM climate control starts at about $350 i think.
driving 01-30-2013 10:42 PM
Are the ac and radio physically part of each other in the back? I'll cut the faceplate and make it work its only bonded by the plastic part
famaya26 01-30-2013 10:45 PM
Won't work because the AC controls are wired with the Radio. If it was that easy, we wouldn't need to spend $350+ to be able to use aftermarket head units.
bigjweb 01-30-2013 11:21 PM
What he ^^^ means is that they share the same circuit board
AkumaMax 01-30-2013 11:57 PM
If cutting the A/C away from the radio was possible people would have done it by now.
bigjweb 01-31-2013 01:25 AM
Why is it always the people with <100 posts always ask these questions?
famaya26 01-31-2013 09:08 AM
Idk man, I gave him the link to the thread he needed and he just ignored it.
bigjweb 01-31-2013 10:12 AM
http://www.sherv.net/cm/emoticons/fi.../head-bash.gif
TheBlackPearl 02-01-2013 06:43 AM
Tsk tsk....
You guys obviously didn't see the thread where the guy separated the OEM radio from the HVAC controls, spliced into the ribbon wire to get its power back, then cut and fiberglass'd the hole for the Double DIN did you?
It looks possible to do, just have to have mad wiring/soldering/electrical skills.
http://legacygt.com/forums/showthrea...ghlight=ribbon
bigjweb 02-01-2013 11:04 AM
Originally Posted by TheBlackPearl (Post 4273418)
Tsk tsk....
All I see is a link to a thread where a guy took apart the radio and has yet to put it back together. If it was that easy, it would have been done already.
famaya26 02-01-2013 09:48 PM
Op, if you want to get an aftermarket HU and improve your sound system. Fork over the $350 for the JDM Double Din Bezel. Otherwise save your money for something else.
compsurge 02-01-2013 10:42 PM
It was completed in another thread.
It is possible.
If you want a factory head unit and better sound, just get a JL Cleansweep, speakers, and an external amp for less than the double DIN conversion kit.
