What did you do to your 5th gen today?? Vol-2
Cleaning up threads to increase server performance and reduce post latency for you all. Previous volume is found here
I drove mine today! :spin:
X |
Post #3!
Checking in for fun. Moaar wheel research while I watch the CUSE game.
Removed my spacers.
Got rid of the OEM tires after 25000 miles and put on Michelin Primacy MXM4's.
I'm here!
Took it to the local alignment ninja again. Holy rear camber! I may have to get one of those whiteline kits for the rear.
-2.4L, -2.2R
Swift springs. Tired ass OEM everything else. |
On the plus side, I was getting a bunch of unpredictable bump steer and was worried I'd have to do a full on roll center kit. Alignment fixed it up nicely. RCK probably wouldn't be a bad idea just the same, but the car no longer surprises me under heavy braking or bumps. |
I gained enough static camber when I lowered my 4th Gen (on Bilsteins/Swifts) that it had between -2.5 to -3.0 camber. Using the stock front camber bolts, I could regain about 1.0 which still left me with -1.5 to -2.0 and a lot of bumpsteer. Once I added the WL BS/RCK, I regained control over my static camber, and the bumpsteer.
If you're lowered, I recommend the WL bits (front and rear) to trim it all out. That and the offset LCA bushings. |
...shopping for wheels and other parts for the spring. With the snow around and me still being on the factory summers my LGT generally stays parked right now.
| All times are GMT -6. The time now is 03:20 PM. |
