Subaru Legacy Forums
Subaru Legacy Forums (
-   Member Classifieds - ARCHIVE (
-   -   '96 Legacy Brighton Wagon Part Out*no linked pics. must attach* (
Lifeisgood 01-25-2013 12:19 PM
1996 Subaru Legacy/Outback Wagon Parts
I have a bunch of stuff left over from two different vehicle part outs I did a while back, one was a White '96 Legacy Brighton Wagon and the other was a Green '96 Legacy Outback Wagon. Please note that I only have the parts listed below and nothing else as both cars have already been taken to the scrap yard.
I'm located in Sandpoint Idaho (about 1.5 hrs NE of Spokane Washington) however I do occasionally make trips down to the Spokane/CDA area and could potentially bring parts with me if someone wasn't in a huge hurry. If you do want a shipping quote for something, I would be more than happy to figure out the weight and measurements of an item so that you can look up the cost yourself (my zip code is 83864).
Please note that everything I have for sale is listed below, I am not a junk yard so please don't ask if I have any other parts. Also, I will remove items as they are sold, so if you see something listed then I probably still have it.
All posted prices are Or Best Offer, so if you see something you want give me a call or shoot me a text, I'd also be glad to discounts if multiple parts were purchased.
Pictures of all the items can be seen at the link below, however I can also take more if needed.
(2zero8) 290-27seven9
Also, I rarely have time to check my PM's so please text or email for fastest response.
Body Parts:
* RF, LF, RR & LR Green Doors, w/Power Windows $75 each
* RF, RR & LR White Doors, w/Manual Windows & Interior Panels $35 each
* Right Front Fender, White (some minor dents but still useable) $25
* Green Hood w/o Scoop (a few dents and not perfect, but over all its strait) $45
Misc Large Items:
* A/C Condensor (sits in front of the radiator) $35
* Factory Roof Rack Cross Bars $45
* (4) Front & Rear Brake Calipers $75
* Automatic Transmission (car had 210k, but it appears to have junk yard #'s on it) $300
* Stock Catback Exhaust w/Muffler $50
* 2.5L Y-Pipe & Both Catalytic Converters $75
* Front Left Hub Assembly w/Disc (ball joint threads damaged) $35
* Front Axle (boot looks good) $35
* Rear Sway Bar w/Endlinks & Bushings $35
* Front Sway Bar w/Bushings $25
* RF, LF, RR & LR Interior Door Panels $25 each
Misc. Switches:
* (8) Door Pin Switches $5 each
* (3) Passenger Power Window Switches $10 each
* Clock Spring/Multifunction Switches (wiper & turn signal) $35
* Rear Window Defroster Switch w/Instrument Cluster Bezel (comes w/plug) $20
* Cruise, Fog & Defroster Switches $15 each
* Power Mirror Switch & Dummy Plug $20 & $5
* Hazard Switch $15
* Hazard Switch w/Center Vent Panel (comes w/plug) $20
Control Modules:
* Engine ECU w/Plugs (and a few inches of wiring) $25
* Automatic Transmission ECU $65
* Cruise Control ECU $20
* Keyless Entry Control Unit (no remotes) $25
* Door Lock, Seatbelt Timer & Shift Lock Unit $20 each
Misc Electronics:
* (2) Front Wiper Motors $25
* (2) Blower Motor Resistor w/Plug $5 each
* Steering Wheel w/Airbag (will not separate) $50
* Steering Wheel/Airbag/Cruise Control Switch $75
* Left & Right Tail Lights $35 each
* 3rd Brake Light $25
* Instrument Cluster w/o Tach (315,546 miles) $25
* Instrument Cluster w/ Tach (210,529 miles) $45
* Engine Bay Fuse Block w/Cover $35
* Radiator Fan (not sure of which side, but can send pictures) $25
* Front & Rear Cigarette Lighter w/Plugs $5 each
* Front & Rear Dome Lights $15 & $10
* Automatic Starter $20
* Horn & Interior Fuse Panel Cover $5 each
* Air Intake w/MAF (no filter or air box) $25
* Washer Pump Motor $10
* Cruise Control Servo/Cable & Motor $25
Other Misc. Parts:
* (2) Center Rear View Mirror $10
* (2) Hood Props & (3) Jack Cranks $5 each
* (1) Rear Hatch Strut (holds good) $20
* Owner's Manual & Maintenance Info Booklets $5
* Steering Column Clam Shell $10
* Front Passenger Seatbelt $25
* Rear Seatbelts (full set) $50
* Washer Tank $15
* Glove Box Latch (no key) $5
* Vacuum Unit (from engine bay) $5
* Hood Hindges (green) $20
* Hood Release w/Cable $20
* Hood Latch $15
* Brake Master Cylinder $25
* ABS Pump w/Wiring $25
Lifeisgood 01-28-2013 04:37 PM
Updated original post with prices, all are OBO of course.
Lifeisgood 04-09-2013 10:32 PM
List updated and several more items added...
Sorry mods, I really don't have the time to upload every single picture individually but each item is priced! All pics are viewable through my photobucket link in the OP. ;-)
c-lo 04-14-2013 07:56 AM
forum rules prohibit linked pics. must be attached to the ad. read about it in the sticky above.
from your first post, click edit, go advanced, manage browse and load.
c-lo 04-16-2013 06:32 PM
closed. op not following rules
