Subaru Legacy Forums
-   Performance/Dyno Numbers/Track Times (http://legacygt.com/forums/forumdisplay.php?f=119)
-   -   I think my turbo might be on it's way out. (http://legacygt.com/forums/showthread.php?t=200362)
urfsin 01-24-2013 10:07 PM
I have a VF39 right now with probably 60,000 or so miles on it (I picked it up used so I don't know for sure). I thought I heard a very slight grinding noise coming from it while I was on the freeway yesterday and I tried to duplicate the noise today, but I had no luck.
So now I am thinking I might need to start looking for a replacement and finally pull the trigger on an aftermarket turbo. Let me first say that I am quite happy with the performance of the VF39. There is nice quick spool up and while the power is not "big" by any means, it's still pretty nice. Edit: I found my old dyno graph and I was making 278 HP and 301 TQ on cali 91 octane.
That all being said, I wouldn't mind a nice little bump in power. If a turbo could to get me to the 320 to 330 HP range and still retain good to decent spool I would be happy. I'm not really interested in going above that power level because my car has 85,xxx miles and it's my DD. I feel these power levels are within pretty safe limits of the stock block / pistons and I like that.
Here is a little background on my power mods: 850cc injectors, fuel pump, custom upgraded TMIC, up pipe and a full turbo back exhaust but that's it. My intake is stock with a drop in K+N filter and my boost control is stock. I am not interested in adding anything to my car except a new turbo.
So here is what I was thinking for my options. I can get a billet wheel for any of these and I think it's probably a good idea because it will help spool to the best of my knowledge.
18G -TD06sl2 (7 or 8cm)
18G -TD06 (7 or 8cm)
20G-TD05 (with a 7cm, it's the "smallest" of the 20g's, but I was thinking this might have nice quick spool and decent top end)
20G - TD06SL2 (7cm or 8cm)
20G - TD06H (I really think this would be overkill, especially with an 8cm and my limited supporting mods)
So what do you think? I would especially like input from members who have experience with these turbo's and mod's similar to time. Thanks in advance. :)
lee07 01-25-2013 08:56 AM
I'd go Avo 380 or hta68 or if you want stock fitment, vf52
Stage 3 came unexpected/ unplanned to me so I just went vf52 but if I planned and researched, Avo 380 would be what I would have gotten
wpmarky 01-25-2013 10:38 AM
http://legacygt.com/forums/showthrea...st-178684.html
urfsin 01-25-2013 12:13 PM
^^ Thanks, I read that already. I am looking for other opinions. I see you have an 18G, what variety and how much power did you make?
wpmarky 01-25-2013 01:16 PM
My spec.b with BNR 18g + 872cc injectors+ FMIC = 330whp on CA91, 392 on e85 (airboy dyno)
http://legacygt.com/forums/showthread.php?t=193268
My 5eat wagon w/ deadbolt 18g + Perrin TMIC + 740cc injectors = 305whp on CA91, 330whp on CA91 + meth (low reading mustang numbers)
http://legacygt.com/forums/showpost....postcount=4807
Infamous1 01-29-2013 03:36 PM
20G-TD06SL2-7cm
wpmarky 01-29-2013 04:09 PM
^^ trust this guy
wurkenman 01-29-2013 05:05 PM
You will love the 20g. You can always tune back a little too.
JMLegacy 01-29-2013 05:40 PM
Where do people go to but turbo's online? I surely don't want eBay.
urfsin 01-29-2013 09:05 PM
Originally Posted by Infamous1 (Post 4268608)
20G-TD06SL2-7cm
Thanks, I was sorta hoping you would chime in. ;)
I have been doing quite a bit of research since I started this thread. I was always drawn to the TD06SL2 compressor wheel because it seems like a good compromise between the TD05 and TD06H.
In regards to the 7cm vs. 8cm: From what I have read, the only bad thing with the 7cm is that you can get boost creep (then have to go with an external waste gate). That is NOT a road I want to go down.
The TD05 with a 8cm seems like an interesting option. There are guys out there running these and the dyno charts look pretty good IMO. I forgot his user name, but one guy is a member here on the forum.
urfsin 01-29-2013 09:14 PM
Not sure what you mean. You can buy IHI, Mistubishi, Forced Performance, Blouch, Garrett and other turbo's online and they are all good.
While I agree that most turbo's on e-bay are a joke, there are a few brands that are OK. You just gotta do your homework and find out what company is ok and what is not. Kinugawa is a good example of a legit "ebay" turbo. They use the same parts as a lot of "big name" turbo companies.
FX35B4 01-29-2013 10:05 PM
Good luck with new turbo set up Dave!
I'll keep eye on your progress;)
urfsin 01-30-2013 09:23 AM
Thanks man. Did you know I still have those race brake pads I bought off you?? :lol: I still have not been back to the track. Funny how you enter a time warp when you have 2 kids! :cool:
xt2005bonbon 01-30-2013 09:34 AM
So wait, you've been two times rally X champ with an OBXT? If yes, that's cool!
JMLegacy 01-30-2013 05:07 PM
Yeah man, these turbos for 1,200+ ...was thinking there must be a better option. But, buying a used one is a gamble especially if bought online on a forum like this.
