Subaru Legacy Forums
-   Suspension/Brakes (http://legacygt.com/forums/forumdisplay.php?f=20)
-   -   Whiteline Fixed 20mm RSB fitment (http://legacygt.com/forums/showthread.php?t=200350)
JJr 01-24-2013 06:22 PM
Simple question, my fixed Whiteline 20mm RSB is 47" wide (endlink mounting points) and the OEM is 46.25" I know it's only 3/8" on each end but will this be a problem? Thx
BarManBean 01-25-2013 06:36 AM
If it is a lgt fitment bar you should be fine. Any difference in geometry of the endlinks should be fixed with washers / spacers though. Add enough washers where they are needed so that the endlinks are perpendicular to the ground.
JJr 01-25-2013 08:28 AM
Will Do! As always, thx for the help BMB.
