Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   Spec B Broblems (http://legacygt.com/forums/showthread.php?t=200298)
SpecBlitzed 01-24-2013 04:56 AM
Spec B Broblems
I was driving to wok and my gas light kicked. Ok low on fuel. As I pulled in to the parking light my cruise light, SI drive light are flashing. Traction control and Check engine light are on. What has happened.
BarManBean 01-24-2013 06:57 AM
I got ninety-nine problems but a spec.Bitch ain't one.
I have no idea.
SCASEYS 01-24-2013 07:02 AM
OMG, car threw a code!
what do I do?
well, like any other car (ever) go get it read and fix it
SpecBlitzed 01-25-2013 04:54 AM
For (every) other car I read the code and that's what it was a CEL code.
Actron Code: P0171 bank 1 system lean
BAC5.2 01-25-2013 05:23 AM
This thread. :facepalm:
JermTheElf 01-25-2013 05:28 AM
Oh lord. What spec b mods have been done
specialB 01-25-2013 06:21 AM
Too much liquid Schwartz not enough gas, duh.
Sent using a porkchop sandwich
luchadorjose 01-25-2013 08:00 AM
Was it cold out? Have you replaced your intake manifold gasket yet? That could be the cause. Just reset the code and be on your merry way
F-WDC Spec B 01-25-2013 08:08 AM
I have that code but thats because my TMIC tabs blew and im waiting for a new one plus i have a vac leak from behind the manifold (subaru should really clamp those down) And i am only stage 1.
What you can first try is to clean your maf? If not that a smoke test. Thats how i found my leaks.
Max Capacity 01-25-2013 08:36 AM
Check the code. A auto parts store will read it for free.
Tighten the gas cap.
max_bobby 01-25-2013 08:51 AM
http://legacygt.com/forums/showthrea...-155325p3.html
F-WDC Spec B 01-25-2013 08:52 AM
^ that too
idiot4hire 01-25-2013 09:03 AM
I'd sell the car for scrap with a code on
max_bobby 01-25-2013 01:36 PM
Buy a LGT it is now a collectors item.
