Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   shave header heat shield points? (http://legacygt.com/forums/showthread.php?t=200280)
05sleeper 01-23-2013 07:40 PM
Got my pnp'd headers to go on but want to wrap them. Has anyone Shaved these off? Or just wrap around them?
http://i234.photobucket.com/albums/e...123_164253.jpg
Nolmers06LGT 01-24-2013 09:11 AM
I've been told a few times that its not a good idea to wrap the headers.. I'd verify that before you start hacking away. Subscribed- I'd like to learn if my source is a liar. :lol:
05sleeper 01-24-2013 10:52 AM
Hmmm I'd be interested to def hear why lol
mwiener2 01-24-2013 11:02 AM
No reason not to wrap headers other than wrap can hold oil which can cause fire. Thermal coating is always a better option.
You're not gonna crack or warp cast headers.
You can cut off the tabs.
05sleeper 01-24-2013 11:22 AM
Fire scares me haha but ok awesome thanks for the info
Max Capacity 01-24-2013 02:14 PM
I know it's kind of late now, what other mods do you have that made you want to pnp the header ?
Have you read about the +/- of doing that over on NASIOC ?
mwiener2 01-24-2013 04:29 PM
What are these Nabisco words of wisdom on headers?
05sleeper 01-24-2013 06:22 PM
Access port, Catless Perrin up pipe, 3" catless down pipe, fms cat back, 3" Perrin turbo inlet, Spt intake, Perrin top mount intercooler with Perrin bpv, stage 2 clutch with lightweight flywheel other suspension bits and Sti center gauges and tons of mounts and bushings and Sway bars about to go on. So headers were really the only bolt on left since I don't have money for turbo yet. And no haven't read pros and cons...I'll have to look.
Max Capacity 01-24-2013 06:32 PM
It's something about you don't want to open up the headed, it will decrease the speed of the flow.
The only porting should be done down around the valve pocket and in the divider area.
If you have all the race parts and make big HP then exhaust porting may do some good.
05sleeper 01-24-2013 07:08 PM
Hmm that's weird, BC I searched and see that some people say it did hurt low end but then most said it actually helps low end BC it gets rid of most of the reversal effect of the flow causing quicker spool and torque and then others said it helps high end lol ugh I which we could find some before and after dyno runs or something
mwiener2 01-24-2013 09:33 PM
What does Nabisco think about GrimmSpeed PnP headers?
