Subaru Legacy Forums
-   Fifth Generation Legacy (2010 - 2014 ) (http://legacygt.com/forums/forumdisplay.php?f=92)
-   -   kw v3 on the way!!!!!!!!!!!! (http://legacygt.com/forums/showthread.php?t=200204)
disgoduc 01-22-2013 06:47 PM
I ordered my v3"s on fri and am looking forward to havin my scoob handle the way it is supposed to..I will post review during and after install....getting excited!!!:rolleyes:
peace,
Dave F...
exbagboy 01-22-2013 06:49 PM
My KW V3 with Swifts springs are here, getting them installed Thursday.
I'll post my review next week.
Kaijubei 01-22-2013 07:50 PM
Will you also post before and after pix? ^.^
exbagboy 01-22-2013 08:08 PM
I already have Swifts springs on but OP could do a stock vs lowered pic. I am planning on dropping it 0.8" only. You from Colorado Kaijubei?
Kaijubei 01-22-2013 08:27 PM
yessir
Blizzard 01-22-2013 08:32 PM
Good luck with that lol. They say 0.8 but it's definitely more than that.
disgoduc 01-23-2013 07:24 AM
Out of curiosity, where did you get your v3's? And what model number are your swift springs? I just got the V3's with the KW springs and was going to look into swifts later if the ride was too harsh, but after reading another member's review about the ride of the KW's on the winter setting I thought I would try stock first. I am the primary driver but the better half takes it to work occationally and she has quite a long ride so ride quality might affect her. Other than that a slightly harsh ride doesn't phase me a bit....
Peace,
Dave F.
killerniceguy 01-23-2013 07:51 AM
Peace,
Dave F.
Just for clarification the winter settings I use and report on is my recommendation, not from KW. Even at the recommended settings from KW I would never describe the ride as harsh, just really firm.
I look forward to reading about your experience, it is night and day!
KNG
Gienek 01-23-2013 11:36 AM
Peace,
Dave F.
Are the Swift springs firmer than the KW V3 springs that come stock on these coilovers? ...Thanks Dave, looking forward to reading your review on this setup. Also, could you recommend or post a link to where you bought them? thanks.
exbagboy 01-23-2013 12:00 PM
I got the KWs from a member here and they came with the Swifts springs which are supposed to be softer than the stock KW springs. I will look for a part number on them.
disgoduc 01-23-2013 12:32 PM
Since the swifts have a larger gap between coils and use a unique material, they are more compliant which in term makes them less.....aggressive when encountering a less than perfect surface. Ultimately the valving, comp and rebound setting is more or less responsible for the actual ride quality. I got my KW's from VR speed factory in Mass. If you go to the website u won't find them in the legacy section you have to go into the universal section and search the kw coil overs and I believe it's on pg 42 or 43...there are a lot of them!!:cool:
Peace,
Dave F
Blizzard 01-23-2013 01:52 PM
KNG
I'm not sure if I agree. The KW settings are harsh IMO. I am using your winter settings recommendation and its slightly stiffer than stock without the horrendous body roll. One thing to note, the colder it gets outside the harsher the ride so I've noticed. Was 7 degrees here this morning lol.
exbagboy 01-23-2013 04:51 PM
Yes, in cold weather I've noticed my stock shocks are firmer and less bouncy, the viscosity of the oil inside the shocks is increased I presume.
