Accessport Not Fully Recording Logs
2 Attachment(s)
Ok, my accessport is only storing about 1/4 of the logs that I do, and the rest never gets recorded. This happens at random, and I dont know how to recreate or fix the problem. Before I do a log, I'm in the live data mode and I hit the "ok" button and wait until "initializing" goes to "logging". Then after the log, I press the "ok" button again. When I pull the logs from the accessport to the computer, via accessport manager, I get this (see attachment). I first wanted to see if anyone had these problems/solution, then I'll talk to Cobb about it. My Accessport has the latest updates btw.
My Log List: -Boost -Load -DAM -Feedback Knock -Fine Learning Knock -Ignition Timing -Knock Sum -MAF -MAF Volt -RPM -Throttle Position -Wastegate Duty Cycle |
Did you post this on the Cobb forum?
If you post on thier Forum, Bill answers question 2x a day, quicker then Tech
1 Attachment(s)
Just an update if anyone cares, I tried to pull the logs off the AP this morning and everything came out correctly (see attachment). Idk why its coming out correct now, but not yesterday.
| All times are GMT -6. The time now is 08:41 AM. |
