Subaru Legacy Forums
Subaru Legacy Forums (
-   Member Classifieds (2005 - 2009) (
-   -   Injector Dynamics Now Available @ Underdog Motorsports! (
Underdog 01-14-2013 02:55 PM
now carries the full line of Injector Dynamics fuel injectors! From the 725cc/min all the way to the monster 2000cc/min model, whether you have top-feed or side-feed fuel rails, ID makes a wide array of injectors that will give you all the fueling you need for your modified Legacy!
Here are two reasons why Injector Dynamics stands above the competition:
Dynamically Matched Sets
Injector Dynamics only sells matched sets, and within each set the dynamic flow rate (slope) will vary no more than +/- 1%, and the dead time (offset) will vary no more than +/- 20 microseconds which is equivalent to +/- 1% at a pulsewidth of 2 milliseconds. It is this dynamic flow matching across the pulse width range that separates the Injector Dynamics from the competition.
Full Dynamic Characterization
Injector Dynamics provides the data that you, your customers and the ECU need to do the job properly. Flow and offset values are provided from 8 to 16 volts across the full pressure range in 5 psi increments. Additionally, ID publishes full dynamic characterization curves: Raw flow vs pulse width, offset corrected flow, linearity curves, and pressure sensitivity plots.
Contact me today for the best possible pricing on all Injector Dynamics injectors! I will provide a quote as quickly as possible and can match or beat any authorized distributors price!
Check out this cool video that ID put together to demonstrate the spray pattern of their ID2000 injectors...
Underdog 01-25-2013 06:10 AM
Good morning! If you have any questions about the ID line of injectors, please don't hesitate to ask. :)
