Subaru Legacy Forums
-   First Generation Legacy (1989 - 1993) (http://legacygt.com/forums/forumdisplay.php?f=94)
-   -   Keyless entry for my '93? (http://legacygt.com/forums/showthread.php?t=199669)
thehandierman 01-14-2013 09:13 AM
I guess even the door locks wear out after 20 years or so. Seems like a common problem. So should I install an aftermarket system to fix my drivers door that I can't get the key to unlock from the outside? Yes I have used lots of oil and cleaning the lock. I have been looking on Ebay and wondered if anyone else has done this conversion. These are only $30.00. Any ideas???
snederhiser 01-14-2013 03:35 PM
Hello;
I had the same problem with my rear lift gate lock. Ended up removing the lock and found one tumbler had to be physically worked to loosen up! Could you switch the lock from the passenger side? These locks are fairly robust and can be worked. I would use the remote actuators as a last resort. Just my two cents, Steven.
mnstrmech 01-15-2013 08:57 AM
i installed a remote start system that had keyless entry feature on my 93. I think sticking a key in a hole is slow anyways.... lol... i like just pushing a button.. i say get a remote keyless entry system and install an actuator in the door..... step into the 20th century... lol....
thehandierman 01-24-2013 05:58 PM
The key-less entry is a success. I installed a key-less entry system from ebay to fix the drives door lock that wouldn't unlock from the outside. You can see what I did on my BLOG.
tripleb117 01-28-2013 10:25 PM
Has anyone had any success with a remote starter on a 1st gen legacy?
mnstrmech 01-29-2013 07:26 AM
ME!!!! lol..... I cant LIVE without a remote start!!!!!! lol..... They are freakin' easy to install.... but i've installed about 500 of them...... anyways... get a system... you dont know what your missing... lol
