Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   Smoke from intercooler, coolant smell? (http://legacygt.com/forums/showthread.php?t=199544)
carlson1984 01-12-2013 10:19 AM
I replaced my turbo a couple of weekend ago and now each time the car is warming up, the car emits smoke out of the Intercooler and I have a pretty heavy smell of coolant in the car. I have been checking the coolant levels in the overflow tank when warm and it does not seem to be going down. Any ideas what this could be and I should check? Thanks
HAMMER DOWN 01-12-2013 11:36 AM
Check coolant hose from turbo to small coolant. Over time the hose balloon & will push coolant pas the spring clamp. I replaced the spring clamps with worm screw clamps for this reason. It a place to start.
Mike
TheBlackPearl 01-12-2013 12:18 PM
Mike
Same here.
Oregon OBXT 01-12-2013 04:39 PM
New turbo should have gotten new hoses. They harden over time. Worm clamps can produce more force but they're masking a tired hose. With new hoses, constant tension clamps are preferred IMO as they compensate for hose deterioration over time without the need to retorque.
AkumaMax 01-12-2013 07:16 PM
Mike
Yep When I replaced my Turbo I had a problem with the coolant hose on it.
-Samurai- 01-14-2013 11:44 PM
Mine just today came loose (literally sprayed everywhere when I wiggled it). So I repositioned the clamp and made sure it was snug. No steam after that. Hopefully doesn't come loose again. The hose itself seems good still. Not crispy or cracked.
