Anyone used Fix-a-Flat before?
I had to deal with two flat tires in the last 5 months and in both incidents neither tire was repairable. I just learned about this fix-a-flat product, does it work on a flat tire that's not repairable?
there is probably a reason why they are repairable..lol
Fix a flat is a super temp fix. It usually doesn't work And if it does, it's usually good for just a few miles. Unless you have a REALLY slow leak. It also makes a real plug or patch (especially a patch) difficult and messy.
Better for mower tires IMO. |
Also it messes up tpms.
ic, what about product like the ultraseal tire sealant: http://www.bulletproofshop.com/Ultraseal-Tire-Sealant
I'm guessing that will gum up the wheel and tpms as well.
How old are your tires?! You drive on the shoulder alot? |
I asked my installer about removing my spare and just using fix-a-flat when I changed tire sizes. He said if I ever bring him a tire that has been exposed to fix-a-flat he will lock his door and send me elsewhere. :lol:
Apparently as stated above it's nasty and gets into everything inside the tire. |
Not to mention some brands use propane as the propellent and if you cause a spark dismounting the tire you might go home with no eyebrows!
Only way I would use it is if I was stuck in the middle of no where. We have customers come in all the time with that crap in there tires. Like I said before it messes up ur tpms and after time will still leak.
FWIW ... I carry a tire plug kit and small 12v compressor.
If I wanted to sabotage someone's car, I would fill a tire with Fix-a-Flat rather than slashing one.
Use fix a flat in your law mower tires not your legacy. It kills tpms sensors. On the can it says its safe for them but I've changed dozens because fix a flat ruined them.
in college, i worked in a gas station, pumping gas, doing oil changes, and changing tires... Fix A Flat would ruin my afternoon sometimes. lol
| All times are GMT -6. The time now is 05:06 AM. |
