Subaru Legacy Forums
-   Fifth Generation Legacy (2010 - 2014 ) (http://legacygt.com/forums/forumdisplay.php?f=92)
-   -   front diff question (http://legacygt.com/forums/showthread.php?t=199239)
Russki 01-07-2013 09:52 AM
front diff question
2011 subaru legacy with cvt. Ive been searching the forums but can't seem to find this. Is the front differential intergrated with the cvt so you dont have to change the oil, cuz there is a drain but no fill
Jay12Legacy 01-07-2013 12:00 PM
Im told there is a seperate fill you take out a sensor thats the fill is what im told give me a couple days ill check for sure when i get back to work
Jay
minuccims 01-07-2013 08:27 PM
The front diff is not the CVT. Separate drain and fill; different fluids.
had posted the info in the past. I've deleted the drawings from the manual. Try searching in the 5th gen area with minuccims, CVT, and 70mm.
If you can't find the thread, let me know and I'll repost the info.
minuccims 01-07-2013 08:42 PM
Ok, that did not work but here is from an older post:
Front differential oil Oil in use Subaru gear oil Extra S 75W-90 (GL-5)
Oil amount: 1.4 liters
Drain plug is on bottom of CVT (T70 plug labeled 'diff oil'). Fill through charge pipe. Don't believe there is a dipstick. You pull the overflow drain plug (beside the main drain plug) to determine when full.
http://legacygt.com/forums/showthrea...ff#post3634233
PoManzAWD 01-08-2013 09:43 AM
I've got an engine oil change coming up in ~1500mi on my 2012 2.5i CVT. If I can find the front diff drain/fill, I'll post some pics.
The CVT drain & fills are straight forward. The drain is on the pan, the fill is up top on the trans case bell housing area, towards the firewall, pass side.
Joel
