V.1 Cobb Accessport issues
Hi Guys,
I have a V.1 Accessport and just recently removed it and got tuned by Infamous tuning. When I bought it I had a serial port on my old computer that was 5 years ago. Computer do not have serial ports anymore at least the 4 computers I have now do not. So I bought a serial to USB converter cable plugged it in and down loaded drivers it found online and still the computers do not see the Accessport. Cobb told me to configure the COM ports. Sorry have no idea how to do that. I have found nothing in searches to figure this out. What in the heck is everybody doing now to use these? Is there a step by step list to configure the port to see the Accessport? I was going to sell this but want to make sure I can give instructions to get it to work. Any help would be great. Scott |
Since your Accessport is unmarried, are you holding the 2 up/down arrow buttons in until you get to the menu list and choose 'connect to PC'(I think) ? Beyond that, ask you question here. They still help out with these questions.
https://forums.cobbtuning.com/forums...ru-AccessTUNER |
only way I could get it to run correctly was on an old laptop with WindowsXP installed and a serial port
I run my StreetTuner with a serial port adapter to my netbook with XP. My AP connects through the software.
Nice one laff79 old laptop with XP and serial port........ Let me give that a try. Outside of an old laptop w/ XP and serial port what are my options? :)
Do what it says |
well I put in a a thread on Cobbs website, we will see. For now anybody else have a clue how to get it to work?
2 Attachment(s)
Bucko3 it shows my adapter is on COM3 and says it is working properly. When I hook up the Accessport to the serial adapter it does nothing. My Accessport does not know it is hooked up nor does my computer see it or do anything. One thing I will point out if this makes a difference is I am using an male/male adapter on my converter.
It should work right? or could the problem be the male/male in between the serial converter and Accessport not compatible? Scott |
Ok tried that still nothing
Maybe try all com ports on your pc. I know mine will only connect on certain com ports no matter what. I'm not home with my pc right now otherwise I could probably give you some other ideas. Are you on xp?
ok I got the Accessport to say waiting for PC by pressing the up/down button right when I gave it power if you wait it will not work. So is says waiting for PC I plugged in the USB with Access map manger open. Nothing, it says "Accessport not connected" and the Accessport is just waiting.
Question I cannot find the old Cobb map maanger CD it came with I have down loaded the newest Map manger which says it covers all older copies. Maybe they are talking about the V.2 Accessport and I need to still use the old version of map manager for this old unit? That is the only thing I can think of. Any ideas |
tried all the Com ports nothing, it could be the map manager looking for the newer V.2 Accessport
That may explain the issue. I'm still not home, but tomorrow, I'll look to see if I have that file I can send you because I think I still have the cd.
| All times are GMT -6. The time now is 07:30 PM. |
