Subaru Legacy Forums
Subaru Legacy Forums (
-   Transmissions (
-   -   What year 5MT are compatible with 07 lgt (
GetShacked808 01-06-2013 08:17 AM
Trans finally quit one me. Was wondering what year wrx 5 speed will work in my 07. Thanks for any and all help.
iNVAR 01-06-2013 07:21 PM
Don't know but the 5MT in WRX are worse than in our cars from what I remember reading.
ripemeat 01-07-2013 01:09 PM
09+ wrx trannies are comparable to 05+ lgt's 5mt strength. I know a few guys with 09+ that are running 400ft lb of torque through those for well over two years.
GTTuner 01-07-2013 01:22 PM
What did you break?
PhilT 01-07-2013 01:45 PM
For a little bit more you can get a STi 6 speed installed, just an option.
GetShacked808 01-08-2013 07:48 AM
Not sure what broke yet, trans is getting pulled today. Bad noise when car is moving and not in gear, as well as noise when clutch is depressed. As far as a 6 spd, I have been looking for one, but finding all the parts and the cost associated is a little daunting.
whitetiger 01-08-2013 08:11 AM
you will have to confirm this, but AFAIK the FD ratio of the 07+ 5mt is 3.92. Any 2.5L WRX trans with that same final drive should fit. (2.0L are push style clutch and would need the accompanying clutch and slave cylinder setup.)
05-06 LGT 5mts use a 4.11 ratio so if you got one of those youd have to find a matching rear diff to put in as well.
GTTuner 01-08-2013 08:26 AM
I have my trans apart as we speak, the center diff driven gear bearings were whirring away.
GetShacked808 01-08-2013 12:34 PM
Trans is pulled, case cracked, 2nd gear said f*** it. I guess the hunt for a 6 spd is on.
