cylinder 3 misfire
just got some blown headgaskets replaced and it drove great for maybe 60 miles. then cylinder 3 quit firing any at all but i smell gas so it must be a spark problem. It started happening when i was doing a 4th gear pull. any ideas what my problem is ?
check the connector and wire thats hooked into the coil pack. also check if coil pack is loose would be my first guess.
ok tganks ill check that i sure hope its not a big internal issue
is it a constant misfire? usually misfires that happen after pulls mean cracked ringland and destroy spark plug. check the spark plug, if it's damaged, borescope your cylinder to examine the piston for missing chunks along the edge.
i checked on the coilpack and bbc84 was right my connecter had broke so it didnt stay attached. thanks for you alls help
| All times are GMT -6. The time now is 01:51 PM. |
