Subaru Legacy Forums
-   Intake and Exhaust (http://legacygt.com/forums/forumdisplay.php?f=73)
-   -   Perrin Turbo Inlet poor fit... (http://legacygt.com/forums/showthread.php?t=199088)
doobaruGT 01-04-2013 06:07 AM
I just wanted to post up for anyone researching that the Perrin Turbo Inlet was a poor fitment on my 05 LGT.
I replaced it thinking I had a tear, but the leak turned out to be the IM Gaskets. I replaced the inlet anyway while I had it out, but the Perrin was nearly 2" too long. It didn't line up with the BPV tubing at all and so I had to modify and cut nearly 2" off of the Turbo side to help it line up with the BPV tube. This, in turn, forced a tighter fit of the vac lines.
It may not be like this for everyone but I just wanted to throw it out there.
Of course, such is the risk with any aftermarket part :spin:
fahr_side 01-04-2013 07:02 AM
Are you sure you bought the correct item? The inlet fit my '08 WRX very well for an aftermarket part, no trimming or kludging at all.
doobaruGT 01-04-2013 07:04 AM
Ill check but I'm not the only one this has happened to so I'm guessing I did buy the correct item.
doobaruGT 01-04-2013 07:09 AM
1 Attachment(s)
Yep, bought the correct one
ripemeat 01-04-2013 07:38 AM
you may need to trim it breh. perrin hasn't always been notable for great fitting products (cough tmic)
doobaruGT 01-04-2013 07:49 AM
Yea I have the Perrin TMIC and strangely enough, it fits perfectly. I must have gotten lucky.
ripemeat 01-04-2013 07:51 AM
that is strange.
wurkenman 01-05-2013 08:36 AM
Mine fit very good, almost a little on the short side. 05 LGT.
doobaruGT 01-05-2013 08:47 AM
Hmmm, some people said that they had to relocate the BPV tube, which would have been fine, except I had zero room to do so.
rhino6303 01-05-2013 12:20 PM
I have one and it fit well. I did unbolt the BPV tube and fit it to the inlet tube first and then re-bolt and fit to BPV. Other than that it fits well. Like I mentioned in your other thread, for me the issue was getting over compressor housing.
