Subaru Legacy Forums
-   Suspension/Brakes (http://legacygt.com/forums/forumdisplay.php?f=20)
-   -   Loud bang. WTH? (http://legacygt.com/forums/showthread.php?t=198627)
JMLegacy 12-25-2012 11:31 PM
Loud bang. WTH?
driving at about 55MPH My right front wheel hit a small sink in the road then I heard a loud BANG. I swore I hit a stone or pothole, but further down in the road another dip caused the same effect again. Is my shocks bad? what could be causing it to bottom out?
I'm on JDM springs and Gr-2 shocks
garudatwo 12-27-2012 11:30 AM
Do you see any leaks from your shocks?
AZP Installs 12-30-2012 09:03 PM
This could be your issue, JDM springs with GR-2 shocks. You most likely hit a pot hole and may have killed the strut, we've seen this in NYC a few times.
-Mike Paisan
http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/14...8/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
JMLegacy 12-30-2012 11:43 PM
What can I do? Bilsteins may not be an option. I also need to look if a boomstop rubber is on there
AZP Installs 12-31-2012 11:58 AM
Koni sport shocks/struts are an option.
-Mike Paisan
JMLegacy 12-31-2012 04:40 PM
Like this?
"GR2s- Stock Replacements
AGX- Nice bump for Auto-x and street performance, adjustability is nice especially if you drive civilians in your car often.
Tokico D Specs- A step up from the AGXs very nicely constructed units.
Konis- Top notch adjustable struts best thing short of going to coilovers for street, auto-x or track applications.
Bilstiens- Great struts, but lack the adjustability of the Konis so I'd rate these as the best non-adjustable setup you can get.
I Like that post, informative. I am saving for the Konis then :)
I have one question, if the struts are stiffer, does that lead to more likely damaging of other suspension (bushings) parts?
AZP Installs 12-31-2012 05:43 PM
Originally Posted by JMLegacy (Post 4225950)
Like this?
Amazon.com: Koni 8610-1447SPORT Externally Adjustable Sport Twin Tube Shock Absorber: Automotive
That resembles something that I posted somewhere!
You won't see any detriment to other things like bushings, however if you have broken bushings like the LCA bushings which are very common on these vehicles, you will see them come to light more prominently once you have a stiffer set of springs or struts.
-Mike Paisan
JMLegacy 12-31-2012 05:50 PM
:D yes, that's your post.
Oh, I'm hearling a low toned clunk when driven on rough roads (think stony road, slow speed)
I did an inspection today, they found no problems.
AZP Installs 12-31-2012 06:01 PM
Could be internal to the struts themselves or the strut tops.
-Mike Paisan
JMLegacy 12-31-2012 06:08 PM
Strut mouts? I see they are cracked and split around the inner circle.
AZP Installs 12-31-2012 07:49 PM
That's probably your issue.
-Mike Paisan
xt2005bonbon 01-02-2013 12:59 AM
Don't we also hear a noticeable 'bang' when the LCA bushings are shot?
AZP Installs 01-02-2013 07:03 AM
You could hear that but if the strut tops are cracked that is likely is issue. The LCA usually pulls hard under breaking when it's shot.
-Mike Paisan
JMLegacy 01-05-2013 02:57 PM
Hey mike, Can I use the KYB strut tops with my car?
Could u recommend one for me? I have some bad road in my daily commute, i'd buy stronger ones if available.
AZP Installs 01-05-2013 09:32 PM
You can use the KYBs. An upgrade would be to use the SpecB ones coupled with the conical washer from your original setup and an additional washer below the conical washer to raise it up.
-Mike Paisan
