Subaru Legacy Forums
-   Member Classifieds - ARCHIVE (http://legacygt.com/forums/forumdisplay.php?f=86)
-   -   FS (OR): Perrin Turbo Inlet PSPINT421 - SOLD (http://legacygt.com/forums/showthread.php?t=198615)
Oregon OBXT 12-25-2012 02:44 PM
1 Attachment(s)
Sold!
Item is new. Was test fit on an 05 OBXT (didnt' fit) and pulled back out. No marks, cuts, etc.
$159.99!
06silvarubiLGT 12-25-2012 04:30 PM
Isn't this the closest to direct fit?
Oregon OBXT 12-26-2012 09:32 AM
According to Perrin, it fits the 08+ WRX and 05-09 LGT. However... it relocates the BOV port to the rear about 1". So it's not an 'easy' fit. I probably could have got it to fit had I removed the intake manifold. Trying to fit it from underneath the intake just wasn't going to happen on the OB, maybe the LGT is better?
You also need to cut your PCV hose and jumper the connector. This is, however, is easy relative to the BOV problem.
c-lo 12-26-2012 10:06 AM
op your pic must be uploaded directly to the site using the manage attachment tool. linked pics are not allowed
doobaruGT 12-26-2012 11:16 AM
ugh, I just bought one 2 days ago
Oregon OBXT 12-26-2012 02:49 PM
How'd it fit? Dd you pull the manifold?
doobaruGT 12-26-2012 02:54 PM
Haven't received it yet. UPS must be slacking in this winter weather.
I'm going to try not to. I'm just going to loosen the Mani enough to lift up and pull the inlet out. If that doesn't work I'm going to pull the whole thing. I'll have lots of time and beer so I'm not concerned. I just want it done right the first time.
Oregon OBXT 12-26-2012 03:11 PM
Don't think 'loosen' is an option. Perrin has directions on their website for both methods. Removal requires draining coolant. IIRC, their method has you pull the BOV hose to the front of the manifold to make the connection and then slide both under the mani.
06silvarubiLGT 12-26-2012 03:40 PM
If you are talking about removing the IM from the TGVs, you wont have much room the fuel lines that go to TGVs are bolted to the bottom of the IM, and are a bitch to get around. Plus if you just loosen and raise the TGVs Im not sure you would be able to get the gaskets over the dowels w/o a fight. just my .02
doobaruGT 12-27-2012 10:51 AM
I just did this two weeks ago when I replaced my IM Gaskets. It's tight but it can be done. Only took about 1.5 hours. Doing the same procedure would afford me a little wiggle room for the Inlet removal/install. Worst case scenario is I have to remove the IM completely which isn't much more work.
1astrokeit 12-27-2012 04:44 PM
Is this still available?
Oregon OBXT 12-27-2012 06:00 PM
Yep!
1astrokeit 12-28-2012 03:05 PM
How much shipped to 08628
Oregon OBXT 12-29-2012 12:07 PM
PM sent.
Oregon OBXT 12-31-2012 10:32 PM
Bump for a new year sale.
