help a newb?
hey fellas. just bought my first turbo car, well, car in general for that matter - and have a few questions.
i want to keep it as stock as possible since i'll be driving it daily, except for a couple comsetic changes... whats the best way to lower about an inch? springs im assuming? recommended brands? i'd also like to move the wheels out a little. does anybody run spacers? thanks in advance |
Get epic springs they are made for stock struts, and some run spacers but most do not recommend them. If I where you your best bet is to get a wider rims and or a off set rim. Hope that helps
at this stage, any info helps. thanks bud.
Tein-H springs are decent too
both feel "stock-ish"?
Yes , epics would be a better choice . It will be a little more harsh then stock but not much
epics for the ride quality? seems the teins are slightly less expensive...
when lowering that amount, 1", is there anything else you have to do besides swap 'em out? would 1" cause any premature wear and tear? |
I recommend swapping the dampers out while your in there. Most likely the OEM ones are worn out by now. I enjoy my Koni and H-Tech combo.
Yes epics have a better ride quality but tein h are just fine and a good price. 1inch is not much of a drop but how ever the stock struts are not made for a inch drop as far as wear and tear or premature failure I wouldn't worry about it it wouldn't make that much of a difference. No just switch your springs that's it.
alright, bear with me... dampers are struts, correct?
i've always had shocks |
Sorry I call shocks and struts dampers.
understood.
there. my avatar pic should explain my newb-ness. |
Sweet jeep. I have a jeep commander also I love it
those black front lips...
wheres the best place to pic one of those up at? ebay? |
What ever you do don't buy s-tech's then are one of the cheapest for a reason
| All times are GMT -6. The time now is 04:26 PM. |
