Subaru Legacy Forums
-   Member Classifieds (2004 and older) (http://legacygt.com/forums/forumdisplay.php?f=103)
-   -   FS(OR): EJ22 Stroker Internals (http://legacygt.com/forums/showthread.php?t=197978)
subikid90 12-12-2012 01:36 PM
2 Attachment(s)
I have decided to go with a different setup for my EJ22T buildhttp://forums.nasioc.com/forums/imag...ies/banana.gif so this stuff is for sale. I have the following parts available,
Wiseco 97.5mm Stroker Pistons
Scat 5.180" connecting Rods
King Engine Bearings Std. #5 Thrust Mains
King Engine Bearings Std. Rods
This is the same thing that 6 star speed sells, only missing the EJ257 crank and much cheaper.
http://6starspeed.com/suej2stenbuk.html
Everything is brand new in packaging still.
The LWP is NOT included!
$850 Shipped and Paypal'd to the lower 48
subikid90 12-13-2012 02:18 PM
Bump
subikid90 12-14-2012 10:40 PM
someone wants power!
spooln30 12-15-2012 12:42 AM
Hey Kyle isnt the crank part of the stroker kit, meaning don't you need the "stroker" crank in order to get the increase in displacement? I've never seen a stroker kit use a OEM spec crank. Or is it just a machining the rod journals to achieve the "stroke"? Just curious.
subikid90 12-15-2012 01:34 PM
The EJ22T is a 75mm stroke, so using the 79mm crank from an EJ257 makes it a stroker. You also have to do a thrust conversion from #3 to #5 to make the EJ257 crank work.
subikid90 12-16-2012 05:57 PM
Bump
subikid90 12-18-2012 12:10 PM
bump
subikid90 12-26-2012 06:47 PM
bump price drop - $850
subikid90 12-27-2012 07:43 PM
bump
subikid90 01-04-2013 10:58 AM
bump
subikid90 01-13-2013 11:10 PM
ttt
subikid90 01-16-2013 01:36 PM
Price drop to $825
subikid90 01-27-2013 07:44 AM
bump
subikid90 02-05-2013 02:15 PM
bump
subikid90 02-12-2013 02:01 PM
ttt
