Location of All Four Mesh Oil Screens?
I have been searching for a definitive list of locations (preferably with pics) of the locations of all four of the mesh oil screens on the EJ255. I removed the most commonly talked about one (turbo oil feed), but want to know where the rest of them are and what components would suffer if they were to get clogged...As well as how common the other locations are to become blocked.
As far as know there are two. the front drivers side can be changed if you cut off the nipple(this also identifies the banjo's with a filter) and use a trimmed wrench, better to do this one when your taking heads off, it's behind the drivers side intake cam gear and rear cover, feeds the OCV. The other is Pass side aft, turbo removal. Use Search link on top of forum. Here's a link for you, more out there.
http://legacygt.com/forums/showthrea...val-62371.html R/Mac |
There are only 2 in your LGT.
| All times are GMT -6. The time now is 06:43 AM. |
