Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   Best oil for new engine break in? (http://legacygt.com/forums/showthread.php?t=197552)
05wagongt 12-05-2012 07:34 PM
Just read after I asked about royal purple that our engines don't like it.....I've only used that on my other cars. I am getting a new engine, is there a oil best suited for break in period? I love in pgh pa if anyone needs to know my climate
ericem 12-05-2012 10:20 PM
Run a motul or castrol 5w30 than switch to a 5w40 .
BAC5.2 12-05-2012 10:39 PM
It doesn't matter.
Max Capacity 12-06-2012 03:35 AM
Pretty much what I did. Castrol GTX
A lot of us change the oil & filter after the 1st 20 minutes of run time. than after 500 miles.
Than after another 1000 miles, then after another 1500 then go to 3500 miles OCI.
Whatisit 12-06-2012 03:52 AM
I say use dino for the first 6k miles aswell. Synthetic is too slippery and will take longer for the piston rings to settle in. Just be aware of your oil level
wurkenman 12-06-2012 04:15 AM
I am using Amsoil and have since the engine spun for the very first time.
bg. 12-06-2012 05:29 AM
I rebuilt my engine in november, currently breaking it in running Castrol GTX 10w-40. Did the first oil change after the car ran for about 30 mins, will change the oil again with conventional at 1000 kms. Then at 3500 kms I will be switching to Motul 5w-40. Like others said, make sure to keep a close watch on your oil level, and keep in mind that the break in period is very important and will determine how well the engine performs and lasts in the future.
Btw you are getting a new engine as in a used one with lower kms? or building your motor?
underground000 12-06-2012 05:47 AM
Mobile 1 for 30 miles but ran the car hard to seat rings (thats what the shop put in)
Amsoil break in for 200 miles then another 200 miles
Then 600 miles on Rotella T (not the T6, just the T)
Amsoil Break-In is a straight weight and has very high levels of zinc?? and Rotella T has high levels too compared to 'normal' oil from what i heard
bluesuby 12-06-2012 03:08 PM
Originally Posted by BAC5.2 (Post 4189058)
It doesn't matter.
What does matter is not running the engine at a constant rpm or over-revving the engine for the first 500 miles. I have used Mobil 1 on 3 cars since day one and all have no problems with oil consumption or rings seating. Porsche and Corvette use synthetic as a factory fill, so they're not buying the dino plan.
06legsleeper 12-06-2012 03:16 PM
redline sells a break in oil... incase you were looking for something like that ... check there site
adreyna 12-07-2012 01:02 AM
this is what i did except i stayed with motul 10-40
seabass07 12-07-2012 01:17 AM
It doesn't matter.
WTFfuck is wrong with you? Haven't you read the oil threads? Rotella T6 is the best oil for all engines under any conditions. Also makes some mean onion rings.
laff79 12-07-2012 01:28 AM
Mmm...love Rotella onion rings with ketchup
05wagongt 12-07-2012 06:24 AM
rebuilt with a 3 yr/unlimited mileage warranty....i triple checked and checked again, the unlimited mileage warranty is correct...and im getting a new turbo to be safe, the garage is taking good care of me...
__raj 12-07-2012 07:33 AM
Subaru factory fill for 5000 miles did us well.
We have a happy stock 05 LGT 5mt wagon with 150k and no internal motor work and original turbo. We use 3k OCI with random dino. Does not burn anything in that short interval.
