STi Intake Manifold
Does anyone know if a 2007 STi intake manifold (red aluminum) is a direct swap for our cars?
From what I understand, both have AVCS and DBW for the USDM market, so I would assume that all of the necessary vacuum and sensor ports are there. |
Like the box and air flow pipe?
If you are thinking that, no it will not swap. |
1 Attachment(s)
No, the throttle body/intercooler setup isn't the same for one
What's needed to make this work?
Ok so my Turbo has 110k miles. Thinking i'm going to need a rebuild in the next year or two. Would it be worth it if one was planning a rebuild?
Wait, you guys know you're in a 5th gen thread right? lol
:lol: no I did not.
You must have been temporarily blinded by the luscious back side on your avatar...:lol:
I know I was. :cool: |
Probably better off attempting to paint your stock intake manifold wrinkle red.
Rutchard, Why do you say that? The EJ255 and EJ257 blocks and heads are essentially the same except for internals.
Other than looks I don't see any reason to put the STi manifold on. No real power gains to be had. Just sounds complicated for the sake of being complicated. |
| All times are GMT -6. The time now is 03:32 AM. |
