Subaru Legacy Forums
-   Wheels/Tires (http://legacygt.com/forums/forumdisplay.php?f=43)
-   -   Ideas for making my own full size spare? (http://legacygt.com/forums/showthread.php?t=197536)
rexva 12-05-2012 03:17 PM
I have an extra tire now due to replacing both front tires at once after one got ruined. I figure since I have the tire and it fits in the wheel well place, under the trunk, I might as well have a full size spare. What's the best way to go about this? Find somebody selling stock wheels? Junkyard? Steelie?
Drift Motion 12-05-2012 03:21 PM
OEM 17s fits near perfect under the sedan trunk cover thing, if you take out the foam thing.
bucko3the7man 12-05-2012 03:35 PM
But I like the foam thing...
Whatisit 12-05-2012 05:30 PM
I tried putting my one of my 09 OEM Spec 18" with OEM RE050 tire under the carpet with the foam removed and it did not fit. I guess if i run a lower profile tire it would have just bearly squeezed in.
rexva 12-06-2012 07:51 AM
That's how I came up with the idea. I like the foam thing though. I guess maybe I should have been more clear. Where would I get an OEM wheel or a steel wheel for this purpose?
rexva 12-06-2012 07:52 AM
Yep same
Drift Motion 12-06-2012 10:26 AM
well, the big foam tray will not fit, but the smaller foam try with the jack and etc will fit, if that makes you guys happier...lol
iNVAR 12-06-2012 02:55 PM
No one else caught this?
You have to check the circumference of your tires between ALL four wheels. NONE of them can differ in circumference by more than 0.25 inches. If so, you must either replace all 4, or you must have the 2 new tires shaved down to match. In addition, ALL 4 tires must be of the same make, model and size.
Consequences of not doing the above is a destroyed center differential.
jacob 12-09-2012 11:47 AM
How much of a concern is it to fun a full size spare of slightly different circumference, due to wear?
iNVAR 12-09-2012 12:00 PM
spares are only meant to be temporary. depends on how bad the wear difference is but I imagine a full size worn tire is better than a donut of any sort. you're supposed to get to a tire shop asap. also keep the temporary tire mounted in the front, at least on my LGT due to the open diff being up front.
rexva 12-14-2012 11:19 AM
Tires were under a year old, maybe 8k miles on them, supposedly 60k mile tires so I figured the wear difference would not be that bad. Obviously I got the same make and model...
iNVAR 12-14-2012 04:05 PM
you're probably fine then but check anyway for peace of mind. 8k isn't exactly nothing like 100 miles would be.
my last set of tires in NYC only lasted about 30k-35k so 8k would be over 25% already...
