Subaru Legacy Forums
-   Third Generation Legacy (1999 - 2004) (http://legacygt.com/forums/forumdisplay.php?f=96)
-   -   need help geting the right struts. (http://legacygt.com/forums/showthread.php?t=197521)
Johnny's-subaru 12-05-2012 10:29 AM
I just got my 2002 legacy back from the subaru dealership and the rear camber is way negative. thay told me it was cause some one before i owned it had installed wagon struts in the rear only. and that putting the right ones in would fix this.
They checked all the bushings, links, arms and sub frame and saw no problems with them. I also did my own inspection and found nothing wrong there.
the driver side rear is at -2.5 and the passenger rear is at -2.6.
so my question is this. I have looked up on different sits struts for my ride but none of them specific if they are for a wagon or sedan.
these are the ones I'm thinking of getting, but are they right?
http://www.rockauto.com/catalog/more...672&cc=1378784
KYB EUROPE Part # 341275 Excel-G; Twin-Tube; Type:Gas Pressure; Mounting Type:Top pin, Bottom eye
Rear Axle
For vehicles without ride height adjustment; For vehicles without electronic suspension control; Exc.: Outback
octain11 12-05-2012 11:12 AM
use the search tool, this topic has been discussed several of times
Johnny's-subaru 12-05-2012 11:49 AM
thanks for the suggestion, but when search this forum for strut topics almost all of them talk about upgrading the springs or a swap.
Am I searching for the wrong key words? :confused:
I would just like some help to know if this struts I'v picked are going to be correct. the site dos not list what body codes its for, just that it fits the European models.
I talked to the site people and they just said that all the info thay have is listed with the part.
F1inspiredLGT 12-05-2012 12:02 PM
KYB would be the OEM direct fit.
Johnny's-subaru 12-05-2012 01:02 PM
Thank you F1inspiredLGT :). you just made my day!:lol:
octain11 12-05-2012 03:48 PM
F1 get the hella out my forum :lol:
F1inspiredLGT 12-05-2012 03:48 PM
You jelly?
octain11 12-05-2012 04:16 PM
i am not jelly, i knew KYB g2 struts will work, there is a new thread every other day about this exact topic.
F1inspiredLGT 12-05-2012 04:36 PM
And that's why I'm here, to help you out. Now where is my "thanks".
octain11 12-05-2012 05:07 PM
here you go... btw OP, while your down there replacing struts, i would do springs as well and check for control arm bushings, and fun stuff like that
