Subaru Legacy Forums
-   Wheels/Tires (http://legacygt.com/forums/forumdisplay.php?f=43)
-   -   Wheels That Fit The '05-'08 Legacy and Outback (http://legacygt.com/forums/showthread.php?t=19741)
axis008 09-30-2005 11:13 PM
Wheels That Fit The '05-'09 Legacy and Outback
I wanted to start a thread similar to that on NASIOC for WRXs and STis for us Legacy and Outback owners (or future ones, like myself).
I have compiled a list of the wheels, sizes, and offsets compatible with the cars.
If there is any information that is missing such as offset or size, please feel free to post.
Also, if your wheel is not on the list, please post the wheel, size, and offset of your configuration. I'd like to have you post your wheel(s) only, to ensure accuracy, or if they are another from another member's car please state their name.
If you have a picture of your wheels mounted, post it or provide a link if possible. I am only posting pictures of the wheels on the car, so that viewers can see what they look like on the car. You can also state if you have suspension or not, but I will not put it in the list. It may somehow help others when they read your post.
If for any reason you want me to either remove your wheel from the list or remove your photo or unidentify your nickname from the picture, I'm a PM away.
Oh, also no Photoshops please. I know some of you have mAd sKiLLz!11 but that would void the point of this post :).
Thank you.
-Ben
*I no longer have the time to input wheels from other threads to this list, so if you'd like your wheel on this list to help out others, please reply. Thanks in advance*
The following format is: Model / Size / Offset / Weight, if stated (Mounted pictures)
Legacy -
17" wheels:18" wheels:19" wheels:Outback -
17" wheels:18" wheels: *I no longer have the time to input wheels from other threads to this list, so if you'd like your wheel on this list to help out others, please reply. Thanks in advance*
03Indigo 10-01-2005 01:33 AM
for the Outback--->
for summer, Rota Tarmac II, 18x7.5", 48mm, and weight is 19.65lbs.
http://www.oakos.com/Merchant2/graph...ROTTARIISG.jpg
First pic, how low the car can go, but there are bump stop issues, so I raised it back up, and the second pic with the Tarmacs shows it at it's current height....about 3/4" higher than the first pic.
http://www.rmcb5.com/albums/album73/IMG_0871.jpg
http://www.rmcb5.com/albums/album92/IMG_1050.jpg
for winter, I have some Sport Editions, 17x7" D5's, 50mm offset, weight is 19lbs. These are actually made by Kosei.
http://www.tirerack.com/images/wheel...e_d5_ci3_l.jpg
here is a pic of them mounted on the car
http://www.rmcb5.com/albums/album73/IMG_1585.jpg
edit: added pic of 17" winter rims mounted on car
axis008 10-01-2005 02:17 AM
Thanks 03Indigo and drewster (through PM)! Keep them coming guys.
Also, 03Indigo, do you happen to have pictures floating around of the wheels mounted? I know you have pictures of the Rota's, I'd like to only put pictures of the wheels mounted if you don't mind, so people could see what they look like on the car. Sorry for the inconvenience.
Thanks,
-Ben
Edit: I found a picture of your Tarmacs, but they are of your car lower than it currently is. If you want to change it, just send me the pic. or post it. Or keep it how it is. Up to you :).
03Indigo 10-01-2005 03:22 AM
updated pic of my car with the rota's. No pics of my winter rims yet, no tires mounted on them. Will be a month or so before they go on the car. When I get those pics, I will post them here, as an edit like I did above.
cheers
jon
axis008 10-01-2005 03:25 AM
Thank you sir!
natethomas2000 10-01-2005 04:20 PM
This will be a great resource for those looking for new wheels. Awesome work!
03Indigo 10-06-2005 01:25 PM
2 Attachment(s)
Pics of the winter 17" rims mounted
Xenonk 10-06-2005 02:37 PM
shouldnt I have over 14 entries on the first post? :p I'll add/fix the post later
rallysquirrel 10-11-2005 11:33 PM
Do ANY 16" rims fit the GT? Like a 16x7 from an RS or 16x7.5 (ROTA has some in that size).
If not is it the width that's the issue, or is it the actual diameter of the wheel that's needed.
I know that for a WRX there are 15" rims
Speedline rally 15"x7"
superlites... http://www.superlite-wheels.com/
revolution wheels... http://www.revolutionwheels.com/
compomotives... http://www.compomotive.com
that fit the 4 pots available on '06, hence my question.
nice to see another CU grad (i'm '99).
axis008 10-12-2005 02:15 AM
I'm not too sure about 16" wheels. I'll have to consult with Xenonk. I don't think they will work because of the brakes. Then again you mentioned the 4-pots from the '06 WRX...
axis008 10-15-2005 01:20 PM
Keefe, do you know the answer the rallysquirrel's question?
Also, I temp. unstickied this in hopes that it could attract more attention.
03Indigo 10-15-2005 09:45 PM
hey, noticed that you had my OBXT 17" rims listed under the 18" rims. ;)
Beanboy 10-15-2005 11:58 PM
Mmm, Rota G-Forces are catching my eye. Wonder what they weigh in 17" form...
-B
dudical26 10-16-2005 09:17 PM
do any 16" wheels fit?
LGT_King 10-17-2005 08:15 AM
I test fitted a 16" x 7" RS rim on my OBXT and it fits with a about 5 mm of clearance from the caliper.
I doubt this will fit the bigger GT brakes however.
16" winter tires here I come!
