Subaru Legacy Forums
-   Legacy Photos (2005-2009) (http://legacygt.com/forums/forumdisplay.php?f=16)
-   -   Zero1's JDM Legacy STi converted USDM 2008 spec.B (http://legacygt.com/forums/showthread.php?t=197350)
Zero1 12-02-2012 01:12 PM
5 Attachment(s)
I think it's about time to start this build thread lol. I bought her brand new on January 15th, 2009 (sat on the lot since August 2007 :( )with 804 miles from the dealer. Sales Manager had put some miles on it so she never got her proper break-in (hence the burning of 1 qt of oil every 1000 miles or so). I have made the most of it though and next on the list for her is a built motor which is probably a couple years out yet. I'll try to start posting more pics as I get time but here's a build list and the first couple of pics I ever took of her (to keep the timeline sequence ;) ).
Mods (>^.^)>
Exterior:
20% tint all around
18x7.5" JDM 2008MY Tuned by STi edition wheels with 235/40-R18 Bridgestone Potenza S04 PP
18x8.5" Volk RE30 wheels
JDM STi rear lip spoiler
JDM rev D-F spec B/STi front bumper w/ FMIC mod
JDM rev D-F spec B/STi power leveling bixenon headlamps
JDM rev D-F spec B/STi grille
Zero Sports carbon fiber mesh grille
JDM/EDM rev D-F front fenders
JDM rev D-F spec B/STi rear bumper w/ dual brake lamps
JDM STi front lip spoiler
JDM STi rubber lip spoiler skirt
JDM aero splash guards
JDM aero strakes
JDM multi-chrome fog lamps
JDM power folding mirrors with Liberal 3-function grampus winkers
S402 badges front/rear (from BP #54/400)
Liberal blue carbon rear STi emblem
Stanza FRP rear window lip spoiler paint-matched
STi polished stainless steel fuel cap cover
DRL delete
Zero Sports oil cap
Zero Sports radiator shroud
Zero Sports alternator shroud
Zero Sports hood scoop diverter
Zero Sports V-Earthing/Effector kit
Zero Sports 1.3 bar silver radiator caps
IAG silver billet aluminum cap and dipstick set
Hella Supertones hidden ;)
JDM Subaru OEM Window Visors
Redline Racing SS Hood Struts
Tommy Kaira lightweight aluminum lug nuts
Interior
JDM Blue LED floor lighting kit
JDM Subaru badged plush trunk mat
Canadian 2008/09MY spec B floor mats
S402 shift knob (from BP #54/402)
S402 door sills (from BL #241/402)
Redline Custom black leather/alcantara with matching silver stich parking brake and shifter boots
EDM/JDM/USDM custom center console and dash/door trim pieces w/ red illuminated cup holders
JDM dual console box w/ OEM alcantara arm rest
STi red stitch steering wheel and horn with custom painted trim pieces
Custom molded triple A-pillar pod
Pillars wrapped in perforated black alcantara
JDM/Custom black headliner and components
Defi Advance CR boost and oil pressure gauges
Zeitronix EGT and A/F ratio combination digital gauge
McIntosh secondary tweeters
Custom door cards
JDM double DIN conversion
*Yet to decide on head unit and nav system*
Suspension and Brakes
STi 6MT short throw shifter kit
Cobb adjustable short throw shifter
Perrin front shifter bushings
STi rear shifter stay bushing
Kartboy pitch stop mount
Cusco power steering rack brace
Whiteline power steering rack bushings
Whiteline tie rod ends
Whiteline rear diff bushings
Whiteline lower ball joints
JDM STi Genome front strut tower bar
S402 BL rear strut tower bar (from BL #194/402)
STi Group N motor mounts
STi Group N trans mount
SPT lower front chassis brace
Tein Flex coilovers with solid aluminum pillow ball upper mounts
Cobb front and adjustable rear sway bars
Cobb rear stabilizer mount brace
Perrin front and rear endlinks
S402 Brembo 6-pot front calipers with custom paint (from BL #241/402)
STi Brembo 2-pot rear calipers with custom paint
Zero Sports SS braided brake lines
Goodridge SS clutch line
KNS Brakes rear Brembo caliper adapters
Custom parking brake shoes via Unclemat @ LegacyGT.com
Brembo 2-piece front rotors and DBA 4000 slotted rear rotors
STi Pink performance front brake pads and Hawk HPS rear brake pads
STi rear pillow ball lateral links
Lots and lots of SS hardware lol
Engine/Power
BNM Performance custom T3 flange twin scroll header, up-pipe, and 2-piece downpipe black ceramic coat
Garage Tuning T3/T4 GT3582R 1.06a/r twin scroll turbo
Twin Turbosmart 40mm EWG
EJ257 case halves honed
Heat-treated STi crankshaft
King Race bearings
JE FSR pistons
Pauter X-Beam rods
Killer B pickup/baffle/oil pan
Gates timing belt/water pump kit
Custom aged ARP head studs
Kelford 272/268 cams
Beehive valve springs/retainers
Agency Power top-feed fuel rails
1600cc Five-O injectors
Custom linear fuel lines with AN fittings
Aeromotive FPR
Full Blown 340lph in tank pump
Integrated Engineering surge tank powder coated w/ Bosch 044 pump
ACT 6-puck ceramic clutch
STi 6MT flywheel
3.5 bar Zeitronix MAP sensor
T1 Motorsports IAT sensor
Cobb Access Port
AVO front mount intercooler
Custom 2.5" aluminum FMIC piping
Custom aluminum CAI with cone filter
Tial Q BOV
Strömung quad-tip cat back exhaust
Kartboy urethane exhaust hanger bushings
Cosworth air pump delete plates
IAG TGV deletes
Crawford V2 recirculating rotated AOS system
Koyo radiator
Zero Sports radiator hoses
Zero Sports magnetic oil drain plug
Mishimoto coolant overflow tank
ARC turbo coolant decompression tank
Semi-wire tuck
She makes some pretty good power :spin:
Drift Motion 12-02-2012 01:28 PM
Love to see the progress!
Gire 12-02-2012 01:33 PM
Great laundry list!
Post up some after pics ASAP. And thanks for sharing.
kanazteck261 12-02-2012 02:09 PM
Interior pics of pillars if you don't mind
Sent from my SCH-I535 using Tapatalk 2
.:Catalyst:. 12-03-2012 10:36 AM
Love the build - JDM goodness! Get some of your current pictures up and would love to see the engine bay and interior as well :) Subscribed!
goobaru 12-03-2012 01:15 PM
20% tint is next on my list
IM SLO 12-03-2012 07:05 PM
Saw this car not too long ago in person. BEAUTIFUL Spec. B So much hard work went into this car and it clearly shows with that fantastic list of modifications. No pictures do this car justice.
Legacsti11 12-04-2012 09:23 AM
I agree with Catalyst Totally
Zero1 12-04-2012 11:30 AM
Gonna try and put some stuff up tonight...
Zero1 12-04-2012 05:45 PM
9 Attachment(s)
Alright, starting from the beginning...
First week of owning the lady she got tint. At this point I was extremely happy I had not purchased the 2009 OBP WRX Premium sedan I had been looking to buy. I ended up spending the same on the spec.B as I would have on the WRX (lots of rebates lol). I had intended on modding the piss out of a WRX but when I got the spec.B I was so giddy about it I honestly didn't want to modify it. That didn't last long at all...
Three months and I installed a Volt HID kit, then a few months later it was Volk RE30 wheels with Limited Edition Formula center caps (hard as hell to find and glad they found a great home Catalyst :) ), Cobb catted TBE (stock exhaust was rusted all to heck and back!), STi 6MT STS with Perrin front and STi rear bushings, SPT front lower chassis brace, Cobb radiator shroud (scooby2.5's now :) ), Cobb battery tie down, SPT intake with heat shield, STi aluminum strut tower bar, SPT oil cap, and an Optima red top.
Still had the TMIC off the car when I took the engine pick lol. It was at this point that the muffler tips not only shot flames between hard shifts but also melted the bumper a little :spin:
Zero1 12-04-2012 06:00 PM
5 Attachment(s)
This one will be a little shorter... Couple weeks later and the rest of the suspension bits came :)
Tein Flex coilovers with solid aluminum pillow ball upper mounts, Perrin front and rear endlinks, and Cobb front and adjustable rear sways. At this point of putting stuff on it was becoming VERY apparent not a whole lot of SS hardware was used from the factory so I started upgrading... all of it lol. And voila! No more monster wheel gap!!!
Time to order JDM goodies right? A LOT of them :wub:
Zero1 12-04-2012 06:38 PM
7 Attachment(s)
The first wave from Japan came in the form of the GTB-STi front end that sat in boxes and traveled half-way across the US with me when I moved to Ohio from Oz. I want to point out that no one knew anything about what was needed at this time summer of 2009 so it was one heck of a learning experience lol. Took a while to figure out that I needed JDM fenders as well lol.
Oh and a super rare set of gen 3(?) JDM Legacy STi wheels that i dearly miss... At least they went to a good home :rolleyes:
Gotta have that plush trunk mat too! And I can always dream about what it will look like eventually...
Zero1 12-04-2012 07:24 PM
9 Attachment(s)
The second most fun I have had modifying her was doing the brakes. My buddy's wife was not a happy camper when I kept them up til the wee hours of the morning using their garage the night before they had to work lol. The fronts were super free and easy while the rears were a PITA. Little bit of modification necessary lol.
Bought brand new (at my cost ;) ) 2004 Impreza STi Brembo calipers and hardware, DBA 2-piece front and single piece rear slotted rotors 2004 Impreza STi fitment, FastWRX.com rear adapters, unclemat's custom extra thick parking brake shoes, Hawk HPS pads (love to have some EBC Red Stuff now...), Goodridge SS lines, and ATE Super Blue fluid.
Gold on gold never looked so fine!!!
Zero1 12-04-2012 08:04 PM
10 Attachment(s)
Winter 2009/2010 was a blast but led to curbing one of the goldies and had to let them go (was told it was unrepairable :( ). 2010 was a LOT of goodies...
TRUNK MONKEY FOR THE WIN!!!
Instead of hole filling, got a new OEM trunk lid to go along with the STi lip spoiler and had them paint-matched along with the license plate trim piece to the rest of her. Thought it would be cool to jazz it up a little so picked up some STi badges and bolted them to the front mats, stuck them in place of the SI-Drive badge, and an OEM Legacy STi trunk badge from Japan. Then had a triple pod A-pillar piece designed for 04-07 Impreza STi fitment custom molded onto my A-pillar and then had all my pillar pieces wrapped in black perforated alcantara matching the rest of the interior. I left all the trim pieces alone as I think the contrast still looks good and man that would have been a nightmare plasti-dipping all those small pieces...
I also found a JDM blue interior lighting kit :) The plug and play connections were not compatible with the USDM wiring so it took a little bit of custom wiring/searching/test-lighting but no air bags were deployed and it was very helpful I already had the pillars taken off. And yes, they are OEM pieces so they come with the timer relay so they shut off a few seconds after the dome lights do ;)
famaya26 12-04-2012 08:12 PM
Def one of my Favorite Leggy conversions. :wub:
