Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   05 lgt 5spd running poorly after new plugs (http://legacygt.com/forums/showthread.php?t=197241)
TenzoGT 11-30-2012 02:00 PM
not my car, but a friend replaced his spark plugs and now the car runs fine when cold or at hyw speeds, but once it gets warm it runs like crap.. sometimes stalling at idle, coils are good everything is connected properly.???? not sure what it might be, anyone?
robitrice 11-30-2012 03:01 PM
were the gapped correctly when they were put in?
Strizzy 11-30-2012 04:26 PM
What brand of plugs? What gap?
TheBlackPearl 11-30-2012 06:06 PM
I've read a couple posts where the problem was the coil pack plug, they get broken, and/or loose during removal.
My .02
321 11-30-2012 06:17 PM
You can try reinstalling old plugs and see if the problem goes away. If it does then you know the problem is with the new plugs. If it dosn't maybe a coil is starting to brake down when it gets hot.
TenzoGT 12-01-2012 08:22 AM
Plugs were purchased from dealer, i dont think the gap was checked. But did put original plugs back in, and it ran bad too.
AZP Installs 12-01-2012 08:58 AM
Could be a bad coil pack or bad coil pack connection. We have seen where the coil pack connectors tend to snap when they are removed/replaced to do the plugs.
-Mike Paisan
http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/14...8/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
TenzoGT 12-01-2012 10:25 AM
there is one of the connectors that had already been zip tied to the coil. but the connection is good. still does not explain running like crap once its warm. or only at idle.
AZP Installs 12-01-2012 10:29 AM
I'll bet you that is your issue.
But hey what do I know...
-Mike Paisan
KNS Brakes 12-01-2012 10:50 AM
-Mike Paisan
Fancy Mike with me at PRI!!
321 12-02-2012 07:25 AM
Have you checked for any codes. You can start pulling injector connectors to pin point which cylinder is giving you issues,
